[GRASS5] [bug #2691] (grass) r.out.ascii parameter width doesn't work
this bug's URL: http://intevation.de/rt/webrt?serial_num=2691
Subject: r.out.ascii parameter width doesn't work
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
GRASS Version: CVS checked out 20041101
I tried to use the width parameter in r.out.ascii
width = Number of values printed before wrapping a line
but this feature doesn't work.
  Otto
The width= option is only used when writing SURFER or MODFLOW format
(-s/-M switches); the GRASS format always writes one text row per map
row.
If that's intentional, it should be more clearly documented.
row.
In GRASS 5.7-CVS:
I have changed the width parm documentation to reflect the "limitation".
Also changed -M to -m for consistency.
