this bug's URL: http://intevation.de/rt/webrt?serial_num=2710
Subject: import mrSid
I want to import images mrSid... Somebody knows if there is a library for
Grass 5.7 that supports this format?
Thanks!
Lourdes
Thanks!
Lourdes
GDAL support MrSID:
http://gdal.org/frmt_mrsid.html
Note that MrSID is not a free algorithm. You need to obtain a license
to compile GDAL with MrSID support.
Then r.in.gdal should read such data.
Another alternative is to export the SID file to TIF + TFW and import with
r.in.gdal
It is not the solution you may want but it could work in the short term.
Stephen
----- Original Message -----
To: <grass5@grass.itc.it>
Sent: Tuesday, November 23, 2004 1:03 AM
Subject: [GRASS5] [bug #2710] (grass) import mrSid
Thanks!
Lourdes
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
r.in.gdal
Related instructions you can find here:
http://mpa.itc.it/markus/shortcourse/notes3.html
