this bug's URL: http://intevation.de/rt/webrt?serial_num=2714
Paul> I think v.llabel is the simple way to do this
Sure wish it was mentioned on v.to.rast.
There is should mention more alternatives than just:
"An empty raster map layer will also be created if the vector map
layer has not been assigned category/attribute labels (e.g., through
use of the v.digit program)"
Also on v.llabel,
A dig_plus file must be created for each imported vector map before it
can be used in v.digit.
It should mention how to do this.
Also v.llabel mentions v.alabel but not visa versa.
--- Headers Follow ---
From jidanni@jidanni.org Wed Nov 24 00:46:35 2004
Return-Path: <jidanni@jidanni.org>
Delivered-To: grass-bugs@lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
by lists.intevation.de (Postfix) with ESMTP id 6B85A102BEC
for <grass-bugs@lists.intevation.de>; Wed, 24 Nov 2004 00:46:35 +0100 (CET)
Received: from localhost (localhost [127.0.0.1])
by mail.intevation.de (Postfix) with ESMTP id 3ECD636DE4
Received: from frodo.hserus.net (frodo.hserus.net [204.74.68.40])
by mail.intevation.de (Postfix) with ESMTP id A95E336CD8
for <grass-bugs@intevation.de>; Wed, 24 Nov 2004 00:46:34 +0100 (CET)
Received: from tc218-187-75-172.2-3.dynamic.apol.com.tw ([218.187.75.172]:35864 helo=jidanni1)
by frodo.hserus.net with esmtpsa
(Cipher TLSv1:RC4-SHA:128) (Exim 4.43 #0)
id 1CWkMh-0005FW-1a by authid <jidanni> with plain; Wed, 24 Nov 2004 05:16:31 +0530
To: grass-bugs@intevation.de
Cc: Paul Kelly <paul-grass@stjohnspoint.co.uk>
Subject: mention v.llabel on v.to.rast
References: <53E31E00-3C29-11D9-BE24-0003937C0D96@unbc.ca>
<871xel19s5.fsf@jidanni.org>
<Pine.LNX.4.60.0411231207210.21957@agrippa.ukshells.co.uk>
Date: Wed, 24 Nov 2004 04:46:12 +0800
Message-ID: <874qjgs38r.fsf_-_@jidanni.org>
MIME-Version: 1.0
Content-Type: text/plain; charset=us-ascii
X-Spam-Status: No, hits=-4.5 tagged_above=-999.0 required=3.0 tests=BAYES_00,
DATE_IN_PAST_03_06
X-Spam-Level:
