[GRASS5] [bug #2723] (grass) configure error with freetype option
this bug's URL: http://intevation.de/rt/webrt?serial_num=2723
Subject: configure error with freetype option
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
GRASS Version: 5.7.0
CFLAGS="-g -Wall" ./configure --enable-shared --with-blas --with-lapack --with-freetype=/usr/lib --with-gdal=/usr/local/bin
checking for location of LAPACK library...
checking for dgesv_ in -llapack... yes
checking whether to use Motif... no
checking whether to use GLw... no
checking whether to use FreeType... /usr/lib
configure: error: *** You must answer yes or no.
You are using --with-freetype wrong. It is a true/false option and you
have given it a directory name. Try just:
--with-freetype
or with
--with-freetype-includes=/usr/include/freetype2
--with-freetype-libs= ...
same with --with-gdal.
see './configure --help | less' for help.
Hamish
