[GRASS5] [bug #2743] (grass) Re: (grass) config.guess failed unknown on Athlon64 with SuSE9.1
this bug's URL: http://intevation.de/rt/webrt?serial_num=2743
Hallo Markus,
leider isses noch nicht gans rund:
ucon04k30:/sc/GRASS/libgrass # ./configure
creating cache ./config.cache
checking for a BSD compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking whether make sets ${MAKE}... yes
checking for working aclocal... found
checking for working autoconf... found
checking for working automake... found
checking for working autoheader... found
checking for working makeinfo... missing
checking for gcc... gcc
checking whether the C compiler (gcc ) works... yes
checking whether the C compiler (gcc ) is a cross-compiler... no
checking whether we are using GNU C... yes
checking whether gcc accepts -g... yes
checking whether ln -s works... yes
checking whether make sets ${MAKE}... (cached) yes
checking host system type... Invalid configuration
`x86_64-unknown-linux-gnu': m achine `x86_64-unknown' not
recognized
checking build system type... Invalid configuration
`x86_64-unknown-linux-gnu': machine `x86_64-unknown' not
recognized
checking for ranlib... ranlib
checking for ld used by GCC... /usr/x86_64-suse-linux/bin/ld
checking if the linker (/usr/x86_64-suse-linux/bin/ld) is GNU ld... yes
checking for BSD-compatible nm... /usr/bin/nm -B
updating cache ./config.cache
loading cache ./config.cache within ltconfig
ltconfig: you must specify a host type if you use `--no-verify'
Try `ltconfig --help' for more information.
configure: error: libtool configure failed
Ich hatte den libgrass-pfad komplett gelöscht und neu geladen.
Mit freundlichen Grüßen / With kindest regards
Stefan Paulick
http://www.urbeli.com
mailto://stefan.paulick@urbeli.com
Markus Neteler via RT schrieb:
Hi Stefan,
I have updated config.guess and config.sub in 5.7-CVS.
Please try again after
cvs up -dP
and let me know if the problem is solved.
--- Headers Follow ---
From stefan@urbeli.com Tue Nov 30 08:31:14 2004
Return-Path: <stefan@urbeli.com>
Delivered-To: grass-bugs@lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
  by lists.intevation.de (Postfix) with ESMTP id B6CC7102BC0
  for <grass-bugs@lists.intevation.de>; Tue, 30 Nov 2004 08:31:14 +0100 (CET)
Received: from localhost (localhost [127.0.0.1])
  by mail.intevation.de (Postfix) with ESMTP id 50C1F3711D
  for <grass-bugs@lists.intevation.de>; Tue, 30 Nov 2004 08:31:10 +0100 (CET)
Received: from mail.bytecamp.net (mail.bytecamp.net [212.204.60.9])
  by mail.intevation.de (Postfix) with SMTP id 4CD0136DE2
  for <grass-bugs@intevation.de>; Tue, 30 Nov 2004 08:31:08 +0100 (CET)
Received: (qmail 85985 invoked by uid 88); 30 Nov 2004 07:30:50 -0000
Message-ID: <20041130073050.85984.qmail@mail.bytecamp.net>
References: <20041129093006.1C67C100169@lists.intevation.de>
In-Reply-To: <20041129093006.1C67C100169@lists.intevation.de>
To: Markus Neteler via RT <grass-bugs@intevation.de>
Subject: Re: (grass) config.guess failed unknown on Athlon64 with SuSE9.1
Date: Tue, 30 Nov 2004 08:30:50 +0100
Mime-Version: 1.0
Content-Type: text/plain; format=flowed; charset="iso-8859-1"
Content-Transfer-Encoding: 8bit
X-Spam-Status: No, hits=-4.9 tagged_above=-999.0 required=3.0 tests=BAYES_00
X-Spam-Level:
