this bug's URL: http://intevation.de/rt/webrt?serial_num=2761
d.path documentation should mention that it uses the mouse to get the
from and to points. One is left wondering until he actually tries the
command out.
The SEE ALSO should mention other batch-job non-display ways of
getting the shortest/longest path.
--- Headers Follow ---
From jidanni@jidanni.org Fri Dec 3 05:07:34 2004
Return-Path: <jidanni@jidanni.org>
Delivered-To: grass-bugs@lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
by lists.intevation.de (Postfix) with ESMTP id 775E6102BC0
for <grass-bugs@lists.intevation.de>; Fri, 3 Dec 2004 05:07:34 +0100 (CET)
Received: from localhost (localhost [127.0.0.1])
by mail.intevation.de (Postfix) with ESMTP id 3CCF93711B
Received: from frodo.hserus.net (frodo.hserus.net [204.74.68.40])
by mail.intevation.de (Postfix) with ESMTP id C8C1236F13
for <grass-bugs@intevation.de>; Fri, 3 Dec 2004 05:07:32 +0100 (CET)
Received: from [219.69.72.5] (port=33578 helo=jidanni1)
by frodo.hserus.net with esmtpsa
(Cipher TLSv1:RC4-SHA:128) (Exim 4.43 #0)
id 1Ca4jD-0000Nf-6h by authid <jidanni> with plain
for <grass-bugs@intevation.de>; Fri, 03 Dec 2004 09:37:31 +0530
To: grass-bugs@intevation.de
Subject: d.path documentation should mention how it gets the from and to
points
Date: Fri, 03 Dec 2004 09:41:56 +0800
Message-ID: <87acswupi3.fsf@jidanni.org>
MIME-Version: 1.0
Content-Type: text/plain; charset=us-ascii
X-Spam-Status: No, hits=-4.9 tagged_above=-999.0 required=3.0 tests=BAYES_00
X-Spam-Level:
