Trying to fix the new (at least recently discovered) bug
in r.stats:
lib/gis/cats.c
int
G_set_raster_cats_title (char *title, struct Categories *pcats)
if (title == NULL) title="";
pcats->title = G_store (title); <- it crashes here
G_newlines_to_spaces (pcats->title);
G_strip (pcats->title);
return 0;
For the crashing map title="" (so above if condition used).
Reverting locally store.c (G_store() function) didn't help.
Clueless,
in r.stats:
lib/gis/cats.c
int
return 0;
G_store() calls G_malloc() which calls malloc().
If a program crashes in either malloc (or calloc, realloc etc) or
free, it's usually because the heap has become corrupted, typically
because something wrote beyond the bounds of a dynamically-allocated
block, overwriting the header of either the current block or the one
after it.
IOW, the crash is just a symptom; the bug lies elsewhere.
Locating this kind of bug can be awkward, as there tend not to be any
detectable side-effects at the point when the memory is corrupted.
There are various tools which can be used, including the MALLOC_CHECK_
environment variable and mcheck/mprobe functions (see the libc Info
file for details), and third-party memory debugging libraries such as
Electric Fence.
