Message of the day:
r.stats -anC fields,elevation.10m
r.stats: 100%
There was a local leftover of my debugging tests in r.stats.
Of course nobody was able to reproduce it (probably only *after*
the G_store() change revert).
Summary:
- G_store() is as it was before
- r.stats is as it was and works
- probably work to do in db.login
I'll close the bug report now.
Thanks for your patience.
