[GRASS5] [bug #2819] (grass) g.copy info message
this bug's URL: http://intevation.de/rt/webrt?serial_num=2819
$ g.copy -o vect=largeCat,largeHouseNumbers
COPY [largeCat@jidanni] to [largeHouseNumbers]
Looks bad. Say
COPY [largeCat@jidanni] to [largeHouseNumbers@jidanni]
or
COPY [largeCat] to [largeHouseNumbers]
--- Headers Follow ---
From jidanni@jidanni.org Thu Dec 9 00:15:50 2004
Return-Path: <jidanni@jidanni.org>
Delivered-To: grass-bugs@lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
  by lists.intevation.de (Postfix) with ESMTP id 14BDC102C35
  for <grass-bugs@lists.intevation.de>; Thu, 9 Dec 2004 00:15:50 +0100 (CET)
Received: from localhost (localhost [127.0.0.1])
  by mail.intevation.de (Postfix) with ESMTP id DBBA836CE0
  for <grass-bugs@lists.intevation.de>; Thu, 9 Dec 2004 00:15:49 +0100 (CET)
Received: from frodo.hserus.net (frodo.hserus.net [204.74.68.40])
  by mail.intevation.de (Postfix) with ESMTP id 0AB9D36CD8
  for <grass-bugs@intevation.de>; Thu, 9 Dec 2004 00:15:49 +0100 (CET)
Received: from [219.69.72.86] (port=32784 helo=jidanni1)
  by frodo.hserus.net with esmtpsa
  (Cipher TLSv1:RC4-SHA:128) (Exim 4.43 #0)
  id 1CcB2B-0003gK-OB by authid <jidanni> with plain
  for <grass-bugs@intevation.de>; Thu, 09 Dec 2004 04:45:48 +0530
To: grass-bugs@intevation.de
Subject: g.copy info message
Date: Thu, 09 Dec 2004 04:58:11 +0800
Message-ID: <87u0qwy0bg.fsf@jidanni.org>
MIME-Version: 1.0
Content-Type: text/plain; charset=us-ascii
X-Spam-Status: No, hits=-4.9 tagged_above=-999.0 required=3.0 tests=BAYES_00
X-Spam-Level:
Looks bad. Say
or
Not sure if we want to change that. In GRASS you can only
copy to the current mapset.
However, I have extended the message to
g.copy vect=roads,test
COPY [roads@PERMANENT] to current mapset as [test]
