[GRASS5] [bug #2835] (grass) v.net.path may just be a special case of v.net.salesman
this bug's URL: http://intevation.de/rt/webrt?serial_num=2835
v.net.path may just be a special case of v.net.salesman, (so say so in
the docs) but who can tell due to the latter's Description being only
one line long. Same with v.net.steiner. Not everybody has gone to GIS
college and would mind knowing what they are about. Takes a .pdf to
learn? Then add the URL. However, many of us are offline, so still
document them. Hate learning that it's too late to click on that last
.pdf now that we have brought our computer to the mountaintop base
station.
Also to v.net.path add: "To avoid v.path taking shortcuts over that
unpaved trail, use three points and v.net.salesman." (If indeed the
case.)
Merely "SEE ALSO v.net.salesman" isn't good enough.
If http://grass.itc.it/grass57/tutorial/network.html is going to be
the permanent URL for any information about these, note it on the man
pages. Often we encounter the man page before the web page.
--- Headers Follow ---
From jidanni@jidanni.org Fri Dec 10 23:10:14 2004
Return-Path: <jidanni@jidanni.org>
Delivered-To: grass-bugs@lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
  by lists.intevation.de (Postfix) with ESMTP id 52195102C0B
  for <grass-bugs@lists.intevation.de>; Fri, 10 Dec 2004 23:10:14 +0100 (CET)
Received: from localhost (localhost [127.0.0.1])
  by mail.intevation.de (Postfix) with ESMTP id E4DC23711B
  for <grass-bugs@lists.intevation.de>; Fri, 10 Dec 2004 23:10:13 +0100 (CET)
Received: from frodo.hserus.net (frodo.hserus.net [204.74.68.40])
  by mail.intevation.de (Postfix) with ESMTP id 4913A36DE2
  for <grass-bugs@intevation.de>; Fri, 10 Dec 2004 23:10:13 +0100 (CET)
Received: from u69-109.u203-187.giga.net.tw ([203.187.69.109]:33188 helo=jidanni1)
  by frodo.hserus.net with esmtpsa
  (Cipher TLSv1:RC4-SHA:128) (Exim 4.43 #0)
  id 1Ccsxj-000Fkk-Mo by authid <jidanni> with plain
  for <grass-bugs@intevation.de>; Sat, 11 Dec 2004 03:40:10 +0530
To: grass-bugs@intevation.de
Subject: v.net.path may just be a special case of v.net.salesman
Date: Fri, 10 Dec 2004 23:05:18 +0800
Message-ID: <87u0qu8a8h.fsf@jidanni.org>
MIME-Version: 1.0
Content-Type: text/plain; charset=us-ascii
X-Spam-Status: No, hits=-4.2 tagged_above=-999.0 required=3.0 tests=BAYES_00,
  DATE_IN_PAST_06_12
X-Spam-Level:
case.)
The correct way to avoid shortcuts is to assign attributes to arcs and use costs from attribute table.
Radim
learn?
Have a look here:
http://mpa.itc.it/markus/teaching.html
Slides of 4th seminar - vector network analysis (Neteler, 10 Mar 2004, 800kb PDF)
(No need to complain if you don't like it)
[stuff deleted]
The URL above is not going to be the permanent URL.
