this bug's URL: http://intevation.de/rt/webrt?serial_num=2852
Subject: Library - libgrass_interpfl.5.7.cvs.dylib - is not built
Platform: Mac OSX
grass obtained from: CVS
GRASS Version: 57cvs_041217
libgrass_interpfl.5.7.cvs.dylib is not built.
Following this lib I have 2 missing bin: r.resamp.rst, v.surf.rst.
Last rows in make:
cc -dynamiclib -Wl,-flat_namespace,-U,_cuserid -compatibility_version 5.7 -current_version 5.7
-install_name /Applications/Grass/grass57cvs.app/Contents/Resources/grass-5.7.cvs/lib/
libgrass_interpfl.dylib -o /Volumes/APPLI/src/grass57cvs_041217/dist.powerpc-apple-
darwin6.8/lib/libgrass_interpfl.5.7.cvs.dylib -L/usr/X11R6/lib -L/usr/local/grasslib/lib -L/
Volumes/APPLI/src/grass57cvs_041217/dist.powerpc-apple-darwin6.8/lib -L/usr/local/pgsql/
lib OBJ.powerpc-apple-darwin6.8/func2d.o OBJ.powerpc-apple-darwin6.8/input2d.o
OBJ.powerpc-apple-darwin6.8/vinput2d.o OBJ.powerpc-apple-darwin6.8/interp2d.o
OBJ.powerpc-apple-darwin6.8/output2d.o OBJ.powerpc-apple-darwin6.8/point2d.o
OBJ.powerpc-apple-darwin6.8/secpar2d.o OBJ.powerpc-apple-darwin6.8/segmen2d.o
OBJ.powerpc-apple-darwin6.8/write2d.o OBJ.powerpc-apple-darwin6.8/matrix.o OBJ.powerpc-
apple-darwin6.8/minmax.o OBJ.powerpc-apple-darwin6.8/init2d.o OBJ.powerpc-apple-
darwin6.8/ressegm2d.o OBJ.powerpc-apple-darwin6.8/resout2d.o -lgrass_gis -lgrass_datetime
-lz -lintl -lgrass_vect -lgrass_dig2 -lgrass_dgl -lgrass_rtree -lgrass_linkm -lgrass_dbmiclient
-lgrass_dbmibase -L/usr/local/grasslib/lib -lgdal -lgrass_bitmap -lgrass_qtree -
lgrass_interpdata -lgrass_dbmiclient -lgrass_dbmibase -lgrass_gmath -L/usr/local/grasslib/lib
-lfftw -framework vecLib -framework vecLib && ln -sf libgrass_interpfl.5.7.cvs.dylib /
Volumes/APPLI/src/grass57cvs_041217/dist.powerpc-apple-darwin6.8/lib/
ld: warning prebinding disabled because dependent library: /Applications/Grass/
grass57cvs.app/Contents/Resources/grass-5.7.cvs/lib/libgrass_gis.dylib is not prebound
ld: Undefined symbols:
_Cats2
_Map2
_Pnts
_count
_driver2
_ff
_sql2
/usr/bin/libtool: internal link edit command failed
NOTE: This library was built in grass57cvs_041213.
