[GRASS5] [bug #2855] (grass) r.reclass GUI bug
this bug's URL: http://intevation.de/rt/webrt?serial_num=2855
Subject: r.reclass GUI bug
Platform: GNU/Linux/i386
grass obtained from: Mirror of Trento site
GRASS Version: grass57_exp_2004_11_13
r.reclass GUI - there is no interface for inputting rules and when you try to run it as it is, it says:
r.reclass input=zgs10kor output=zgs10kor_recl
no rules specified
Use the "reclassify using rules" menu entry in the GUI (r.reclass.rules
script). I guess I thought this was pretty clear.
Michael
no rules specified
____________________
C. Michael Barton, Professor of Anthropology
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
try to
no rules specified
Ah, ok. I simply typed r.reclass& and got the described problem, I didn't
know that an alternative exist in the d.m menu so I didn't look for it. Now
I have what I need but anyway some issues arise:
1. The GUI entry for r.reclass is described as "Reclassify categories using
rules file". What file? Is r.reclass GUI usable anyway?
2. r.reclass.rules doesn't have a manual thus according to the manual the
only module containing this funcionality is r.reclass. A manual is
desirable to avoid confussion.
3. Scripts in /etc/dm/script/ and /tcltkgrass/script/ cannot be invoked from
the command line. Shouldn't they be?
Thanks
Maciek Sieczka
Maciek,
R.reclass.rules is a script that gives access to interactive rule input via
the GUI. Interactive rule input is described under r.reclass, but is not
available via the autogenerated GUI. It is available via the command line,
following the format described in the r.reclass manual.
I relooked at r.reclass. The autogenerated GUI dialog is completely useless.
I seem to remember that it had an input for a rules file last summer but it
doesn't now. Whether I am remembering wrong or it has changed I don't know.
The r.recode autogenerated GUI is equally useless. I could write a script
that allows input of a text rules file to be piped to the command, but it
would be better if this was built into the GUI (as is the case with
v.reclass).
As far as I know, you can't get to any interactive terminal use via the
autogenerated GUI. The same problem affects r.colors (so I wrote a similar
script there).
The manual is incorrect in showing 2 forms of interactive use in the
terminal. The interactive format in which the user has a screen showing
current values and can input a new value cannot be accessed in GRASS 5.7--at
least I have no idea of how to get there. You can get to that screen if you
use GRASS 5.4. It's too bad, as it is a nice way to reclassify or recode
values for many discrete value raster (and vector) maps.
These kind of interactive modules need to be updated to be functional under
GRASS 5.7, but I think there are some considerable difficulties to be
overcome. There are not many of these, but they are important. Interactive
reclassification is a significant function. It is not available for vectors.
It is available for rasters using rules (but not by changing individual
values) via the command line but on via a script from the GUI.
This would be a good project for a new volunteer programmer to take on.
Michael
try to
no rules specified
Thanks
Maciek Sieczka
PO Box 872402
USA
Phone: 480-965-6262
Fax: 480-965-7671
