this bug's URL: http://intevation.de/rt/webrt?serial_num=2857
Subject: v.digit doesn't display properly
Platform: GNU/Linux/i386
grass obtained from: Mirror of Trento site
GRASS Version: grass57_exp_2004_11_13
In v.digit when I display a raster of res=10 together with vector lines, which should perfectly overlay it, then after a few zoom in/out these two layers start to disynchronize to an extent of half the res. Also it happens that one or two cells of the raster layer fail to display at all. Moreover, if any of this faults happen and I close the v.digit, then any d.rast or d.vect still give the same faulty display until changing region settings with g.region. If that's not clear what I mean I can post 2 example screendumps, please let me know.
Maciek Sieczka
