[GRASS5] [bug #2877] (grass) Insecure tempfile creation
this bug's URL: http://intevation.de/rt/webrt?serial_num=2877
Subject: Insecure tempfile creation
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
GRASS Version: 5.7.0
This is a showstopper bug for Debian. Packages with security bugs cannot enter the stable distribution. This is Debian Bug #287651:
http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=287651
Received: (at submit) by bugs.debian.org; 29 Dec 2004 11:01:19 +0000
From jfs@dat.etsit.upm.es Wed Dec 29 03:01:19 2004
Return-path: <jfs@dat.etsit.upm.es>
Received: from tornado.dat.etsit.upm.es (dat.etsit.upm.es) [138.100.17.73]
  by spohr.debian.org with smtp (Exim 3.35 1 (Debian))
  id 1CjbZu-00028E-00; Wed, 29 Dec 2004 03:01:18 -0800
Received: (qmail 10639 invoked by uid 1013); 29 Dec 2004 11:01:16 -0000
Date: Wed, 29 Dec 2004 12:01:16 +0100
From: Javier =?iso-8859-1?Q?Fern=E1ndez-Sanguino_Pe=F1a?= <jfs@computer.org>
To: submit@bugs.debian.org
Subject: grass: Multiple vulnerabilities (symlink attacks) due to improper temporary files use in scripts and source code
Message-ID: <20041229110116.GB7144@dat.etsit.upm.es>
Mime-Version: 1.0
Content-Type: multipart/signed; micalg=pgp-sha1;
  protocol="application/pgp-signature"; boundary="VrqPEDrXMn8OVzN4"
Content-Disposition: inline
User-Agent: Mutt/1.5.6+20040722i
Delivered-To: submit@bugs.debian.org
X-Spam-Checker-Version: SpamAssassin 2.60-bugs.debian.org_2004_03_25
  (1.212-2003-09-23-exp) on spohr.debian.org
X-Spam-Status: No, hits=-8.0 required=4.0 tests=BAYES_00,HAS_PACKAGE
  autolearn=no version=2.60-bugs.debian.org_2004_03_25
X-Spam-Level:
Package: grass
Version: 5.0.3-5.1
Priority: grave
Tags: security sarge sid
A lot of scripts provided withing Grass are vulnerable to race conditions
through symlink attacks in temporary files. Many of these scripts either
create temporary files in an insecure manner (shell scripts do not use 'set
-e' and 'set -C', for example) or/and are easily guessable.
Some examples include:
grass-5.0.3/src/scripts/contrib/i.oif/i.oif:
# save the Stddev for TM bands
echo "Calculation Standarddeviations for all bands:"
$GISBASE/etc/i.oif/r.stddev $1 |tail -1 >/tmp/i.oif.stddev
grass-5.0.3/src/CMD/generic/GISGEN.sh:
case $# in
0)
    tmp1=/tmp/GISGEN1.$$
    tmp2=/tmp/GISGEN2.$$
    tmp3=/tmp/GISGEN3.$$
    rm -f $tmp1
        touch $tmp1
   rm -f $tmp2
    rm -f $tmp3
    echo "a == 1 { print \$0 ; next }" > $tmp3
    echo "\$0 == \"$STEP\" { a = 1; print \$0 }" >> $tmp3
    awk -f $tmp3 $tmp1 > $tmp2
    rm -f $tmp3 $tmp1
grass-5.0.3/src/mapdev/v.in.arc.poly/script/v.in.arc.poly
bindir=$GISBASE/etc
tempfile=/tmp/temp.ply
echo 'start eliminating double nodes in ' $1
$bindir/permut $GISDBASE/$LOCATION_NAME/$MAPSET/arc/temp.ply $tempfile
rm $tempfile
[Note: permut just opens this output file without further checks:
./src/mapdev/v.in.arc.poly/permut/permut.c
       if ((outfile = fopen (out_ply, "w")) == NULL)
          printf ("can't open tempfile %s\n", out_ply);
          exit (1);
./src/paint/Drivers/versatec/3236/DRIVER.sh
TMPDIR1=/tmp/versatec
TMPDIR2=/tmp/versatec
RASTERFILE=$TMPDIR1/_paint
SPRINT="/bin/sprint >&2"
SPRINT_COMMAND="$SPRINT $RASTERFILE -v -p 3236 -w $TMPDIR2 -x $ZOOM -y
$ZOOM"
grass-5.0.3/src/scripts/contrib/i.spectral/i.spectral
.where -1 |r.what input=$RASTERMAPS > /tmp/spectr.dum1
cat /tmp/spectr.dum1 | cut -d'|' -f4,5,6,7,8,9,10| tr '|' '\012' >
/tmp/spectr.dum2
Now those are just exmaples of the "easily guessable" temporary files used.
But a lot of scripts make use of the $$ construct (either within shell
scripts or C code using getpid()) that is not directly guessable but can be
infered in a system where a given user is running grass more or less
accurately either:
- by looking at the /tmp/ directory and detecting when a given temporary
file is created and symlink the "next one". For example in
./src/scripts/contrib/r.plane/r.plane the following tmp files are created
in succession: /tmp/$$, /tmp/$$dip, /tmp/$$, /tmp/$$ea, /tmp/$$, /tmp/$$no,
/tmp/$$ (removed and reused several times). So an attacker
- by bulk creating a huge number of temporary files using the current PID
of the grass program as a base
Just try a 'grep -r "/tmp/"' on the sources and you'll see what I mean.
I cannot determine, as I don't use grass, wether the scripts there are
actually used regularly by users. I would suggest however to patch those
either by:
a) Safely creating a per user temporary directory and have all scripts use
that as a location for all of the temporary files if defined. For example,
in a common startup script do:
TMPGRASS = `mktemp -dt grass-XXXXXX` || { echo "Cannot create temporary
directory"; exit 1 ; }
export TMPGRASS
and in auxiliary scripts do:
[ ! -n "TMPGRASS" ] && TMPGRASS=`mktemp -dt grass-XXXXXX` || { echo "Cannot
create temporary directory"; exit 1 ; }
tempfile="$TMPGRASS/tempfile"
b) Changing all shell scripts to use mktemp or tempfile (might
make those Debian-specific) when setting up temporary files.
All the C files, however, need to be modified so that they use mkstemp().
So, for example, instead of this:
(in grass-5.0.3/src/imagery/i.ask/popup.c):
   char tempfile1[40], tempfile2[40];
   sprintf (tempfile1, "/tmp/i.ask1.%d", getpid());
   sprintf (tempfile2, "/tmp/i.ask2.%d", getpid());
it should use this:
    int tempfd1; int tempfd2;
    if ( ( tempfd1 = mkstemp("/tmp/i.ask1.XXXXXX") ) < 0 ) {
      /* Do something if this breaks! */
    if ( ( tempfd2 = mkstemp("/tmp/i.ask2.XXXXXX") ) < 0 ) {
and pass the filedescriptor (instead of the filename) to functions later
on. This means that ./src/libes/raster/Panel.c needs to be rewritten (or
extended to use fd instead of names in its call.
BTW, what does this mean?
grass-5.0.3/src/libes/raster/Panel.c
  /* make sure this file can be written by anybody */
        num = umask(0);
        close(creat(name,0666));
        umask(num);
Doesn't look too safe to me.. What's the panel used for?
Now, I'm not sure I can provide a patch fixing all of those, but I'm
willing to provide a full patch (at least for the shell scripts) if time
permits.
However, IMHO this makes this software package unsuitable for release.
Regards
Javier
Dear javier,
thanks for pointing out the insecurities.
But the package you refer to is quite old.
Perhaps you do not know the debian-gis-mailinglist, which can be joined
here: http://lists.alioth.debian.org/mailman/listinfo/pkg-grass-general
There are affords to prepare an unofficial GRASS5.7-package, and
actually there is an apt-getable repository available.
Probably you would like to give it a try.
deb http://pkg-grass.alioth.debian.org/archive unstable main contrib non-free
deb-src http://pkg-grass.alioth.debian.org/archive unstable main contrib
non-free
If you would like to send patches for debian, I suggest to create the
patches against this version, if the problems are still in there.
Thanks
  Stephan
On Wed, 29 Dec 2004 17:28:52 +0100 (CET) Request Tracker
[138.100.17.73]
-0000 Date: Wed, 29 Dec 2004 12:01:16 +0100
<jfs@computer.org> To: submit@bugs.debian.org
improper temporary files use in scripts and source code Message-ID:
<20041229110116.GB7144@dat.etsit.upm.es> Mime-Version: 1.0
X-Spam-Level:
Package: grass
Version: 5.0.3-5.1
Priority: grave
conditions through symlink attacks in temporary files. Many of these
scripts either create temporary files in an insecure manner (shell
scripts do not use 'set-e' and 'set -C', for example) or/and are
easily guessable.
case $# in
0)
    rm -f $tmp1
        touch $tmp1
   rm -f $tmp2
    rm -f $tmp3
    rm -f $tmp3 $tmp1
bindir=$GISBASE/etc
rm $tempfile
          exit (1);
$ZOOM"
/tmp/spectr.dum2
used. But a lot of scripts make use of the $$ construct (either within
shell scripts or C code using getpid()) that is not directly guessable
but can be infered in a system where a given user is running grass
more or less accurately either:
temporary file is created and symlink the "next one". For example in
created in succession: /tmp/$$, /tmp/$$dip, /tmp/$$, /tmp/$$ea,
/tmp/$$, /tmp/$$no,/tmp/$$ (removed and reused several times). So an
attacker
PID of the grass program as a base
mean.
those either by:
use that as a location for all of the temporary files if defined. For
example, in a common startup script do:
export TMPGRASS
"Cannot create temporary directory"; exit 1 ; }
mkstemp(). So, for example, instead of this:
it should use this:
later on. This means that ./src/libes/raster/Panel.c needs to be
rewritten (or extended to use fd instead of names in its call.
        num = umask(0);
        umask(num);
time permits.
Regards
Javier
Tracker
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Stephan Holl
Check headers for GnuPG Key!
http://www.gdf-hannover.de
On Wed, 2004-12-29 at 19:58 +0100, Stephan Holl wrote:
Dear javier,
non-free
I've been working on this package and the few examples I checked are
still in the 5.7.0 release. I suspect they are in CVS as well. That's
why I took the liberty of forwarding this bug to the grass bug system.
As far as debian goes, it is probably best to patch the 5.0.3 package in
most cases since that has the best chance of making it into the next
release. I don't think it would be hard in most cases to forward port
these fixes.
Steve
Thanks
  Stephan
> [138.100.17.73]
> X-Spam-Level:
> Package: grass
> Version: 5.0.3-5.1
> Priority: grave
> easily guessable.
> case $# in
> 0)
> rm -f $tmp1
> touch $tmp1
> rm -f $tmp2
> rm -f $tmp3
> rm -f $tmp3 $tmp1
> bindir=$GISBASE/etc
> rm $tempfile
> exit (1);
> $ZOOM"
> /tmp/spectr.dum2
> attacker
> mean.
> those either by:
> export TMPGRASS
> it should use this:
> num = umask(0);
> umask(num);
> time permits.
> Regards
> Javier
> Tracker
> grass5 mailing list
> grass5@grass.itc.it
> Dear javier,
> non-free
these fixes.
Thanks for doing this - the GRASS developers are so few and have their
noses so close to the wheel, that seeing things like this, which are
vital, can be hard. If a per-session temporary directory is a good
solution, there may be code in the R codebase that can help, because that
is the way it is done there. Probably the full path and directory name
would have to be kept in the users' .grassrc*. My guess would be that
rather than modify 5.0.*, the decision would fall between 5.4 and 5.7,
with my preference for 5.7, because that is where most of the developers'
attention is - 5.4 should then be clearly marked to suit.
Security does matter, and this bug report is very relevant, and also
suggests remedies.
Roger
Steve
> Thanks
> Stephan
> > [138.100.17.73]
> > X-Spam-Level:
> > Package: grass
> > Version: 5.0.3-5.1
> > Priority: grave
> > easily guessable.
> > case $# in
> > 0)
> > rm -f $tmp1
> > touch $tmp1
> > rm -f $tmp2
> > rm -f $tmp3
> > rm -f $tmp3 $tmp1
> > bindir=$GISBASE/etc
> > rm $tempfile
> > exit (1);
> > $ZOOM"
> > /tmp/spectr.dum2
> > attacker
> > mean.
> > those either by:
> > export TMPGRASS
> > it should use this:
> > num = umask(0);
> > umask(num);
> > time permits.
> > Regards
> > Javier
> > Tracker
> > _______________________________________________
> > grass5 mailing list
> > grass5@grass.itc.it
grass5 mailing list
grass5@grass.itc.it
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Breiviksveien 40, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 93 93
e-mail: Roger.Bivand@nhh.no
these fixes.
I think g.tempfile is the 'correct' way to create temporary files in GRASS scripts.
But no one ever said GRASS was secure. In fact I thought the general consensus was that it was riddled with security-related bugs? (Especially versions < 5.7 where there is lots of code that hasn't been touched for many years)
Paul
