[GRASS5] [bug #2904] (grass) v.in.sites for larger site files does not finish
this bug's URL: http://intevation.de/rt/webrt?serial_num=2904
Request number 2904 was commented on by 'guest' (guest user).
Responding to this message will send mail to the requestor.
      Request Tracker
      rt@intevation.de
Cc: grass5@grass.itc.it
I tried to track down the problem - here is more detailed info, but no
solution yet:
The transfering of sites to vector file seems to slow down as the number
of points increases (maybe db_append_string has to go through everything
that has been written each time it adds a new point?)
but the real problem seems to be in db_close_database(driver) -
the program spends by far the most time on that function,
for illustration, 280000 points takes 3 minutes doing the transfering sites
to vect file but it spends 8 minutes on db_close_database and it extremely
slows down the machine (windows, mouse practically don't work on my computer
during those 8 minutes). Everything else runs for a negligible time.
Slower importing of 280000 points is not really a problem, but
for larger files (500000+) I was unable to get it past
db_close_database(driver) after running it for hours.
So the bug apperas to be somewhere in lib/db/dbmi_driver/d_closedb.c or
d_close_cur.c, but I am only guessing here.
It will be in the driver implementation of db__driver_close_database(),
either in save_table() or free_table() in grass51/db/drivers/dbf/db.c.
Can you please try to comment the free_table (i); ( row 110 )
in the grass51/db/drivers/dbf/db.c.
In theory, one driver can be reused for another database, but AKAIK
it is not in current GRASS. So it is faster just close the driver.
OTOH, it can become a problem if DBMI swith to dlopen because of windows port.
Radim
Request number 2904 was commented on by 'guest' (guest user). Responding to this message will send mail to the requestor.
      Request Tracker
      rt@intevation.de
solution yet:
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
