[GRASS5] [bug #2916] (grass) errors in DEFAULT_WIND in a location made from epsg code
this bug's URL: http://intevation.de/rt/webrt?serial_num=2916
Subject: errors in DEFAULT_WIND in a location made from epsg code
Platform: GNU/Linux/i386
grass obtained from: Mirror of Trento site
GRASS Version: grass-6.0.cvs_src_snapshot__2005_01_15
In the menu invoked by 'grass60 -gui' I set up a new location from an epsg code '2174'. After entering it any g.region command gave:
ERROR: default region is invalid
line 13: <cols3: -1073745292>
Today I used this functionality as one of the examples for a bunch of ArcView addicts of how easy it is to work in Grass6. We were rather impressed but not with g.region's output ;).
The problematic DEFAULT_WIND looks as follows:
north: 1
south: 0
east: 1
west: 0
cols: 1
rows: 1
e-w resol: 1
n-s resol: 1
top: 4.14363e-310
bottom: -1.99674
cols3: -1073745292
rows3: 24641422
depths: 1073826200
e-w resol3: 2.16093445
n-s resol3: 0
t-b resol: 0
Maciek Sieczka
Ah, I see. g.proj is missing an update for the WIND3 integrated.
Fixed in CVS.
north: 1
south: 0
east: 1
west: 0
cols: 1
rows: 1
e-w resol: 1
n-s resol: 1
top: 4.14363e-310
bottom: -1.99674
cols3: -1073745292
rows3: 24641422
depths: 1073826200
n-s resol3: 0
t-b resol: 0
Maciek Sieczka
So, here we are:
GRASS 6.0.cvs:~ > g.proj -p
-PROJ_INFO-------------------------------------------------
proj : stere
a : 6378245
es : 0.0066934216
lat_0 : 51.67083333333333
lon_0 : 16.67222222222222
k : 0.999800
x_0 : 3703000
y_0 : 5627000
towgs84 : 33.4,-146.6,-76.3,-0.359,-0.053,0.844,-0.84
no_defs : defined
-PROJ_UNITS------------------------------------------------
unit : metre
units : metres
meter : 1
GRASS 6.0.cvs:~ >
Now you can show your bunch of ArcView addicts the bug fix response time...
Reported: Fri Jan 21 2005 00:31:35
Fixed: Fri Jan 21 2005 11:51:45 CET
Time difference: around 11h including the night.
It is available in CVS, will appear in the next Saturday's CVS snapshots and
of course in 6.0.0beta2.
Have fun, thanks for reporting
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
