Here is a backtrace:
(gdb) r srtm.dem el=rst ew_res=10 ns_res=10
Percent complete: 0%
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 1086126496 (LWP 24161)]
0x4064995c in mallopt () from /lib/tls/libc.so.6
(gdb) bt
#0 0x4064995c in mallopt () from /lib/tls/libc.so.6
#1 0x406473fd in malloc () from /lib/tls/libc.so.6
#2 0x40517d31 in G_malloc (n=Variable "n" is not available.
) at alloc.c:23
#3 0x40542fba in G_site_new_struct (cattype=Variable "cattype" is not available.
) at sites.c:80
#4 0x4002c5d7 in IL_check_at_points_2d (params=0x804d340, data=Variable
"data" is not available.
at point2d.c:67
#5 0x4002f8f6 in IL_resample_interp_segments_2d (params=0x804d340,
bitmask=0x0, zmin=Variable "zmin" is not available.
) at ressegm2d.c:565
#6 0x0804af10 in main (argc=5, argv=0xbffff2a4) at main.c:573
Probably it is related to the cross validation changes.
