[GRASS5] [bug #2937] (grass) v.in.ogr, GUI, fails during "Building areas:"
this bug's URL: http://intevation.de/rt/webrt?serial_num=2937
Subject: v.in.ogr, GUI, fails during "Building areas:"
Platform: GNU/Linux/i386
grass obtained from: Mirror of Trento site
GRASS Version: grass-6.0.cvs_src_snapshot__2005_01_15
My system: Mdk10.1, gcc 3.3.4.
v.in.ogr works fine directly from the terminal, but fails during "Building areas:" when invoked from GUI. Then it prints to the terminal as follows:
GRASS 6.0.cvs:~ > too many nested evaluations (infinite loop?)
    (procedure "GlobalVar::exists" line 1)
    invoked from within
"GlobalVar::exists $_widget($path,var)"
    (procedure "ProgressBar::_modify" line 4)
    invoked from within
"ProgressBar::_modify .dialog0.progress"
    ("eval" body line 1)
    invoked from within
"eval ProgressBar::$cmd .dialog0.progress $args"
    (procedure ".dialog0.progress" line 1)
    invoked from within
"$opt($dlg,progress) _modify"
    (procedure "progress" line 7)
    invoked from within
"progress $dlg $val"
    invoked from within
"if [eof $fh] {
                close $fh
        } else {
                set str [gets $fh]
                append str "\n"
                if { [fblocked $fh] } { set str [read $fh] }
                while {[set idx [string f..."
    (procedure "prnout" line 5)
    invoked from within
"prnout 1 file6"
GRASS 6.0.cvs:~ >
Here goes the message displayed in the GUI widnow during import, prior to failure:
v.in.ogr dsn=/home/maciek/polska_shp/granica92/granica.shp output=granice min_area=0.0001 snap=-1
A datum name etrs89 (European_Terrestrial_Reference_System_1989) was specified without transformation parameters.
Note that the GRASS default for etrs89 is towgs84=0.000,0.000,0.000.
Projection of input dataset and current location appear to match.
Proceeding with import...
Layer: granica
Building topology ...
Registering lines:
43 primitives registered
Building areas:
41 areas built
41 isles built
Attaching islands:
Attaching centroids:
Topology was built.
Number of nodes : 42
Number of primitives: 43
Number of points : 0
Number of lines : 0
Number of boundaries: 43
Number of centroids : 0
Number of areas : 41
Number of isles : 41
Number of incorrect boundaries : 2
Number of areas without centroid : 41
Cleaning polygons, result is not guaranteed!
Topology was built.
Number of lines : 0
Number of areas : -
Number of isles : -
Break polygons:
Registering points ... 3154
All points (vertices): 5033
Registered points (unique coordinates): 3154
Points marked for break: 81
Breaks: 0
Breaks: 30
Breaks: 47
Breaks: 74
Breaks: 108
Breaks: 143
Remove duplicates:
Duplicates: 0
Duplicates: 1
Duplicates: 2
Duplicates: 3
Duplicates: 4
Duplicates: 5
Duplicates: 6
Duplicates: 7
Duplicates: 8
Duplicates: 9
Duplicates: 10
Duplicates: 11
Duplicates: 12
Duplicates: 13
Duplicates: 14
Duplicates: 15
Duplicates: 16
Duplicates: 17
Duplicates: 18
Duplicates: 19
Duplicates: 20
Duplicates: 21
Duplicates: 22
Duplicates: 23
Duplicates: 24
Duplicates: 25
Duplicates: 26
Duplicates: 27
Duplicates: 28
Duplicates: 29
Duplicates: 30
Duplicates: 31
Duplicates: 32
Duplicates: 33
Duplicates: 34
Duplicates: 35
Duplicates: 36
Duplicates: 37
Duplicates: 38
Duplicates: 39
Duplicates: 40
Duplicates: 41
Duplicates: 42
Duplicates: 43
Duplicates: 44
Duplicates: 45
Duplicates: 46
Duplicates: 47
Duplicates: 48
Duplicates: 49
Duplicates: 50
Duplicates: 51
Duplicates: 52
Duplicates: 53
Duplicates: 54
Duplicates: 55
Duplicates: 56
Break boundaries:
Intersections: 0
Intersections: 0
Remove duplicates:
Duplicates: 0
Clean boundaries at nodes:
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Modifications: 0
Change dangles to lines:
Removed dangles: 0 removed lines: 0
Remove bridges:
Removed bridges: 0 removed lines: 0
Building areas:
43 areas built
19 isles built
Attaching islands:
Topology was built.
Number of nodes : 81
Number of primitives: 186
Number of lines : 0
Number of boundaries: 186
Number of areas : 43
Number of isles : 19
Number of areas without centroid : 43
Layer: granica
Registering lines:
148 primitives registered
Building areas:
Maciek
Could you send me the shapefile?
Radim
    invoked from within
    invoked from within
    invoked from within
    invoked from within
    invoked from within
    invoked from within
"if [eof $fh] {
                close $fh
        } else {
                set str [gets $fh]
                append str "\n"
    invoked from within
"prnout 1 file6"
GRASS 6.0.cvs:~ >
v.in.ogr dsn=/home/maciek/polska_shp/granica92/granica.shp output=granice min_area=0.0001 snap=-1 A datum name etrs89 (European_Terrestrial_Reference_System_1989) was specified without transformation parameters.
Layer: granica
Registering lines: 43 primitives registered Building areas:
41 areas built 41 isles built
Attaching islands: Attaching centroids: Topology was built.
Number of lines : 0
Topology was built.
Number of lines : 0
Number of areas : -
Number of isles : -
Break polygons:
Breaks: 0
Breaks: 30
Breaks: 47
Breaks: 74
Breaks: 108
Breaks: 143
Remove duplicates:
Duplicates: 0
Duplicates: 1
Duplicates: 2
Duplicates: 3
Duplicates: 4
Duplicates: 5
Duplicates: 6
Duplicates: 7
Duplicates: 8
Duplicates: 9
Duplicates: 10
Duplicates: 11
Duplicates: 12
Duplicates: 13
Duplicates: 14
Duplicates: 15
Duplicates: 16
Duplicates: 17
Duplicates: 18
Duplicates: 19
Duplicates: 20
Duplicates: 21
Duplicates: 22
Duplicates: 23
Duplicates: 24
Duplicates: 25
Duplicates: 26
Duplicates: 27
Duplicates: 28
Duplicates: 29
Duplicates: 30
Duplicates: 31
Duplicates: 32
Duplicates: 33
Duplicates: 34
Duplicates: 35
Duplicates: 36
Duplicates: 37
Duplicates: 38
Duplicates: 39
Duplicates: 40
Duplicates: 41
Duplicates: 42
Duplicates: 43
Duplicates: 44
Duplicates: 45
Duplicates: 46
Duplicates: 47
Duplicates: 48
Duplicates: 49
Duplicates: 50
Duplicates: 51
Duplicates: 52
Duplicates: 53
Duplicates: 54
Duplicates: 55
Duplicates: 56
Break boundaries:
Intersections: 0
Intersections: 0 -----------------------------------------------------
Remove duplicates:
Duplicates: 0
Modifications: 0
Remove bridges:
Building areas:
43 areas built 19 isles built
Attaching islands: Topology was built.
Number of lines : 0
Layer: granica
Registering lines: 148 primitives registered Building areas:
Maciek
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Radim Blazek <blazek@itc.it> wrote:
Ah, only from GUI? I thought that it fails also from command line.
The current GUI (TclTk) does not have future, for me.
Radim
So would somebody be willing to take care of this bug?
Maciek
----- Original Message ----- From: "Request Tracker" <grass-bugs@intevation.de>
To: <grass5@grass.itc.it>
Sent: Monday, January 24, 2005 11:54 PM
Subject: [GRASS5] [bug #2937] (grass) v.in.ogr, GUI, fails during "Building
areas:"
   invoked from within
   invoked from within
   invoked from within
   invoked from within
   invoked from within
   invoked from within
"if [eof $fh] {
               close $fh
       } else {
               set str [gets $fh]
               append str "\n"
   invoked from within
"prnout 1 file6"
GRASS 6.0.cvs:~ >
failure:
Layer: granica
Registering lines:
Building areas:
41 areas built
41 isles built
Attaching islands:
Topology was built.
Number of lines : 0
Topology was built.
Number of lines : 0
Number of areas : -
Number of isles : -
Break polygons:
Breaks: 0
Breaks: 30
Breaks: 47
Breaks: 74
Breaks: 108
Breaks: 143
Remove duplicates:
Duplicates: 0
Duplicates: 1
Duplicates: 2
Duplicates: 3
Duplicates: 4
Duplicates: 5
Duplicates: 6
Duplicates: 7
Duplicates: 8
Duplicates: 9
Duplicates: 10
Duplicates: 11
Duplicates: 12
Duplicates: 13
Duplicates: 14
Duplicates: 15
Duplicates: 16
Duplicates: 17
Duplicates: 18
Duplicates: 19
Duplicates: 20
Duplicates: 21
Duplicates: 22
Duplicates: 23
Duplicates: 24
Duplicates: 25
Duplicates: 26
Duplicates: 27
Duplicates: 28
Duplicates: 29
Duplicates: 30
Duplicates: 31
Duplicates: 32
Duplicates: 33
Duplicates: 34
Duplicates: 35
Duplicates: 36
Duplicates: 37
Duplicates: 38
Duplicates: 39
Duplicates: 40
Duplicates: 41
Duplicates: 42
Duplicates: 43
Duplicates: 44
Duplicates: 45
Duplicates: 46
Duplicates: 47
Duplicates: 48
Duplicates: 49
Duplicates: 50
Duplicates: 51
Duplicates: 52
Duplicates: 53
Duplicates: 54
Duplicates: 55
Duplicates: 56
Break boundaries:
Intersections: 0
Intersections: 0
Remove duplicates:
Duplicates: 0
Modifications: 0
Remove bridges:
Building areas:
43 areas built
19 isles built
Attaching islands:
Topology was built.
Number of lines : 0
Layer: granica
Registering lines:
Building areas:
Maciek
Hi
I had problem with the v.in.ogr GUI again with another file. This time nothing was printed to terminal and the whole GIS Manager and all windows freezed and I had to kill the GUI. The file failed to import. Here's a screendump attached of the v.in.ogr and the error pop-up.
In the next d.m session trying to import this file from GUI once more crashed again, but this time the GUI survived and the error, similar to the bug report below, was printed to the terminal. Again, importing this file in command line works ok.
Maciek
Subject: [GRASS5] [bug #2937] (grass) v.in.ogr, GUI, fails during "Building areas:"
   invoked from within
   invoked from within
   invoked from within
   invoked from within
   invoked from within
   invoked from within
"if [eof $fh] {
               close $fh
       } else {
               set str [gets $fh]
               append str "\n"
   invoked from within
"prnout 1 file6"
GRASS 6.0.cvs:~ >
Layer: granica
Registering lines:
Building areas:
41 areas built
41 isles built
Attaching islands:
Topology was built.
Number of lines : 0
Topology was built.
Number of lines : 0
Number of areas : -
Number of isles : -
Break polygons:
Breaks: 0
Breaks: 30
Breaks: 47
Breaks: 74
Breaks: 108
Breaks: 143
Remove duplicates:
Duplicates: 0
Duplicates: 1
Duplicates: 2
Duplicates: 3
Duplicates: 4
Duplicates: 5
Duplicates: 6
Duplicates: 7
Duplicates: 8
Duplicates: 9
Duplicates: 10
Duplicates: 11
Duplicates: 12
Duplicates: 13
Duplicates: 14
Duplicates: 15
Duplicates: 16
Duplicates: 17
Duplicates: 18
Duplicates: 19
Duplicates: 20
Duplicates: 21
Duplicates: 22
Duplicates: 23
Duplicates: 24
Duplicates: 25
Duplicates: 26
Duplicates: 27
Duplicates: 28
Duplicates: 29
Duplicates: 30
Duplicates: 31
Duplicates: 32
Duplicates: 33
Duplicates: 34
Duplicates: 35
Duplicates: 36
Duplicates: 37
Duplicates: 38
Duplicates: 39
Duplicates: 40
Duplicates: 41
Duplicates: 42
Duplicates: 43
Duplicates: 44
Duplicates: 45
Duplicates: 46
Duplicates: 47
Duplicates: 48
Duplicates: 49
Duplicates: 50
Duplicates: 51
Duplicates: 52
Duplicates: 53
Duplicates: 54
Duplicates: 55
Duplicates: 56
Break boundaries:
Intersections: 0
Intersections: 0
Remove duplicates:
Duplicates: 0
Modifications: 0
Remove bridges:
Building areas:
43 areas built
19 isles built
Attaching islands:
Topology was built.
Number of lines : 0
Layer: granica
Registering lines:
Building areas:
Maciek
grass5 mailing list
grass5@grass.itc.it
(attachments)
