this bug's URL: http://intevation.de/rt/webrt?serial_num=2963
Subject: GRASS command history equivalent to .Rhistory
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
GRASS Version: 6.0.0beta1 (*.deb)
I am not sure if it is easily implemented but a history for GRASS commands
(separated by mapsets) like the history file in R would be very handy. Martin
I have
mlennert@moritz:~/GRASSDATA/BELGIQUE/mlennert$ ls -a
. .bash_history cats cellhd colr hist .tmp vector windows
.. .bashrc cell cell_misc dbf paint VAR WIND
What else than the .bash_history file would you want (or is this only
available in bash ?) ?
Moritz
> commands (separated by mapsets) like the history file in R would be very
> handy.
I have
uphs, sorry, wish can be deleted, I thought that also the regular unix
commands I entered before I started GRASS were listed but I forgot that I can
use Unix commands as well inside GRASS session and that the Unix commands I
saw were actually entered in the GRASS session not in the previous shell.
Martin
I have
.bash_history and the 'history' command are features of the Bash shell.
Adding such a feature for better history support should not be terribly
difficult, but it is clearly not a priority.
Brad Douglas <rez@touchofmadness.com>
> > handy.
> I have
This is because etc/Init.sh temporarily sets HOME to the mapset
directory while it starts the shell, so $HOME/.bash_history refers to
a mapset-specific history file.
You can set HISTFILE prior to starting GRASS if you want to override
it (e.g. if you want a single history file for all GRASS sessions).
