this bug's URL: http://intevation.de/rt/webrt?serial_num=2990
Subject: v.surf.rst fails when called from GUI and in command-line mode
Platform: GNU/Linux/i386
grass obtained from: Mirror of Trento site
GRASS Version: 6.0 beta2
Calos Henrique Grohmann
code: grass6.0beta2.
When I try to call v.surf.rst from the GUI, when I
click over it I get:
child process exited abnormally
while executing
"exec -- v.surf.rst >@ stdout 2>@ stderr"
("eval" body line 1)
invoked from within
"eval exec -- $cmd $args >@ stdout 2>@ stderr"
(procedure "run" line 2)
invoked from within
"run v.surf.rst"
invoked from within
".#menubar.#menubar#menu3.#menubar#menu3#menu26 invoke active"
("uplevel" body line 1)
invoked from within
"uplevel #0 [list $w invoke active]"
(procedure "tkMenuInvoke" line 47)
invoked from within
"tkMenuInvoke .#menubar.#menubar#menu3.#menubar#menu3#menu26 1
v"
(command bound to event)
and in the terminal:
ERROR: Required parameter <input> not set:
(Name of the vector file with input data).
but how could I give the input if the window didn't even open?
NOTE: according to Moritz Lennert, it could be a problem with how the module is called by the GUI (it is called via the "run" procedure and not "execute" like v.surf.idw)
and, If I try to call it from the terminal:...
GRASS 6.0.0beta2:~ > v.surf.rst input=cn_clip3d layer=0 zcolumn=ELEV
elev=teste
Authors: original version - H.Mitasova, L.Mitas, I. Kosinovsky, D.P. Gerdes
See manual pages for reference and publications
Percent complete: Reading lines from vector map ... Warning: some points
outside of region -- will >ignore...
100%
Reading nodes from vector map ... 100%
100%
Warning: strip exists with insufficient dataWarning: there are points outside specified region--ignored 25362 points
The number of points from vector file is 1464201
The number of points outside of region 25362
The number of points being used is 1438839Processing all selected output files
will require 1530928 bytes of disk space for temp files
Percent complete: Warning: taking too long to find points for
interpolation--please change the >region to area where your points are.
Continuing calculations...
G_ludcmp() failed! n=0
ERROR: Interp_segmets failed
GRASS 6.0.0beta2:~
the points are there, inside the region, so how could it not find them???
