this bug's URL: http://intevation.de/rt/webrt?serial_num=2997
Subject: v.in.ascii: add skip header lines option
(points mode)
It would be nice if v.in.ascii had a skip=int option to skip the top n lines
of an input file. Often a .csv file will have a comment and column headings at
the start of the file and data will start on line 3-5. Resaving without is a
pain and leaves behind .csv data files which are impossible to figure out even
just an hour later (at least for me).
Hamish
