this bug's URL: http://intevation.de/rt/webrt?serial_num=2998
Subject: d.m menu: v.convert has a bad description
v.convert's menu entry:
File -> Import -> Vector -> Import/Export old GRASS vector format
should be just "Import old GRASS vector format"
Export functionality was never written. (use v.out.ascii -o format=standard)
along the same lines:
File -> Export -> Vector -> Import/Export old GRASS vector format
should be removed.
and:
File -> Export -> Vector -> ASCII points file from GRASS sites file
should be removed (s.out.ascii not built by default and is only there for
debugging purposes)
same with:
File -> Import -> Vector -> ASCII points file to GRASS sites format
and:
File -> Export -> Vector -> GRASS vector file
might be renamed as-
"ASCII file or GRASS ASCII-vector format or old GRASS ASCII-vector format"
... but hopefully something more concise than that.
v.out.ascii exports:
- '|' delimeted ascii text file
- GRASS ASCII-format files
- old GRASS ASCII-format files for import into 5.0/5.4 etc.
It's a pity to hide all that functionality. Maybe make three menu items with
options pre-programmed?
Hamish
Reply-To: Request Tracker <grass-bugs@intevation.de>
Date: Tue, 15 Feb 2005 07:08:04 +0100 (CET)
To: <grass5@grass.itc.it>
Subject: [GRASS5] [bug #2998] (grass) d.m menu: v.convert has a bad
description
Fixed in CVS
should be removed.
Fixed in CVS
and:
debugging purposes)
Fixed in CVS
same with:
Fixed in CVS
and:
Fixed in CVS
This would require 3 scripts. Maybe something to consider for 6.1/6.2
Hamish
______________________________
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
