[GRASS5] [bug #3071] (grass) nviz: finer height panel step needed
this bug's URL: http://intevation.de/rt/webrt?serial_num=3071
Subject: nviz: finer height panel step needed
Platform: GNU/Linux/i386
grass obtained from: Mirror of Trento site
GRASS Version: grass-6.0.cvs_src_snapshot_2005_02_12
A subtle height fine-tuning option is necessary for comfortable detailed visulization.
By now the height panel step is over 100m. That's ok for general overviewing, but it is impossible to change the height right according to the user need.
Maciek
to the user need.
The step is dynamic depending on raster min/max. You can enter an exact
or out-of-range height in the text box & apply by pressing enter.
does that cover your needs?
Hamish
Subject: Re: [GRASS5] [bug #3071] (grass) nviz: finer height panel step needed
to the user need.
Yes, I know that.
No. E.g. I'm selecting frames for animation of a DEM. Consider the first frame - say height 1000 is too much and 900 too little - how do I know if I need 950, 960, 971, 983 or else? Now multiply this dilema by your number of frames. Fine tuning each frame height manually is uncomfortable and time consuming. Maybe it could be aided by a slide bar, where one would choose his height-step from between 1 up to this automatically derived factor depending on raster min/max.
Maciek
Hello,
As Hamish mentioned, the height scale and resolution are set automatically
according to the data being loaded.
The height min/max and resolution do get updated if a different value is
entered. For example if a height is entered that is larger than the max of
the scale it will automatically be updated to reflect the entered value.
The same situation applies to the resolution. Try entering 0.5 for a new
height. This should reset the height resolution to 0.5.
Hope this helps.
Bob
needed
to the user need.
Yes, I know that.
Maciek
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
