Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
GRASS Version: grass-6.0.cvs_src_snapshot_2005_03_05
child process exited abnormally
while executing
"exec -- d.mon start=CELL >@ stdout 2>@ stderr"
("eval" body line 1)
invoked from within
"eval exec -- $cmd $args >@ stdout 2>@ stderr"
(procedure "run" line 2)
invoked from within
"run d.mon start=CELL"
invoked from within
".#menubar.#menubar#menu2.#menubar#menu2#menu4 invoke active"
("uplevel" body line 1)
invoked from within
"uplevel #0 [list $w invoke active]"
(procedure "tkMenuInvoke" line 47)
invoked from within
"tkMenuInvoke .#menubar.#menubar#menu2.#menubar#menu2#menu4 1
"Welcome to GRASS 6.0.cvs (2005)
GRASS homepage: http://grass.itc.it/
This version running thru: Bash Shell (/bin/bash)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
If required, restart the graphical user interface with: d.m &
When ready to quit enter: exit
GRASS 6.0.cvs (lafay_gdal):/ext2e/data/GRASSDATA > Could not execute monitor: No such file or directory
No socket to connect to for monitor <CELL>.
Problem selecting CELL. Will try once more
while executing
The CELL driver was not ported (yet?) to GRASS 6.
Please use the PNG driver which is even more powerful.
The CELL driver has been non-functional since the switch to 5.7 (now 6). I
don't know why it still shows up as existing when you list available
monitors, but this should probably be disabled--unless there are plans to
revive the CELL driver.
Michael
______________________________
Arizona State University
Tempe, AZ 85287-2402
USA
while executing
invoked from within
invoked from within
invoked from within
invoked from within
invoked from within
6). I don't know why it still shows up as existing when you list
available monitors, but this should probably be disabled--unless there
are plans to revive the CELL driver.
Markus:
Is there any point/advantage to having a CELL driver anymore?
What could it be used for that can't be done via another path?
Markus:
Given that both the CELL and PNG drivers behave in a near-identical
manner, i.e. store values in a 2D "array" then convert the array to an
external representation upon either termination or R_close_driver(),
there should probably be some re-factoring in that area.
IOW, either:
a) merge the CELL and PNG drivers so that the CELL functionality is
essentially just another output "target" (e.g. if GRASS_PNGFILE
doesn't end in ".png" or ".ppm", it's treated as a map name), or
b) move the bulk of the PNG driver into a library; either the existing
driverlib or a new library specifically for drivers which behave like
the CELL and PNG drivers.
