this bug's URL: http://intevation.de/rt/webrt?serial_num=3087
Subject: high cpu usage
Platform: GNU/Linux/i386
grass obtained from: Mirror of Trento site
GRASS Version: 6.0.0
some commands, like d.zoom, d.what.rast or d.what.vect using about 50% or more of cpu resources. there is no problem with this in grass54. my cpu is pentium 4 2.8ghz.
best,
maciek
This is a known problem with all programs which use the mouse.
Essentially, to prevent the program from pausing until a mouse button
is pressed, the code (libraster) polls for mouse events in a busy-wait
rather than blocking until a mouse event is received (as was the case
in 5.4 and earlier).
To: "Request Tracker" <grass-bugs@intevation.de>
Cc: <grass5@grass.itc.it>
Sent: Monday, March 14, 2005 1:05 AM
Subject: Re: [GRASS5] [bug #3087] (grass) high cpu usage
But a very serious one and requiring a fix if possible.
I'm not the one who reported on this (that was another Maciek ) so I
might not remember details, but as far as I know them guys use this machine
(P4 2.8 GHz, 4GB RAM) as a server for 12 Linux stations during GIS/Grass
classes and courses at the Wroclaw University. And when few users use any
d.* simultanously command on Grass6 it causes a complete deadlock of the
server and the only solution is to reset it. Which makes students, Grass
newbies in most, doubt in Grass quality.
Due to this they still stick to Grass 5.4 in spite of 6.0 being such a great
and advanced software.
Maciek Sieczka
Yeah, various people have complained about this, but it has been
neither fixed nor reverted.
AFAIK, it's only required for the newer v.digit and d.what.vect, due
to the "form" library. The problem with the original implementation
was that the program would block while waiting for a mouse press.
A better solution would have been to leave the original (working)
mouse handling untouched and to have implemented the "enhanced"
version as separate operations. That way, only the programs which
actually need the new version would cause problems.
