this bug's URL: http://intevation.de/rt/webrt?serial_num=3141
Subject: v.out.ascii: support for outputting attribute columns
see http://grass.itc.it/pipermail/grass5/2005-April/017933.html
Radim:
The possibility to export attributes should be added to v.out.ascii,
but it must be done better than in v.out.ogr. All attributes must be
selected by one query and read points using category index and keep an
array of flags if the point was printed. At the end output points
without attributes.
agreed, best solution.
option
key: columns ("where="?? "sql="??)
type: string
description: attribute columns to export
required : no
multiple: yes
cats= can be done with the above option too, right?
Hamish
