[GRASS5] [bug #3146] (grass) NVIZ: limitation regarding volume data
this bug's URL: http://intevation.de/rt/webrt?serial_num=3146
Subject: NVIZ: limitation regarding volume data
Platform: GNU/Linux/i386
grass obtained from: CVS
GRASS Version: 6.1CVS
NVIZ currently features a limitation for the max number of volumes.
This limit is arbitrarily set to 100, there are apparently no such limitations for surfaces, etc.
This causes strange effects and/or unexpected stops when scripting is used for batch-processing of lots of data.
It is strongly suggested to increase the default value of the variable
MAX_VOL_FILES in /libogsf/gsds.c to a significantly higher value.
Peter
Looking at:
cd lib/ogsf
grep MAX_VO *
gsurf.h:#define MAX_VOLS 12
GVL2.c:static int Vol_ID[MAX_VOLS];
GVL2.c: if (Next_vol < MAX_VOLS) {
gvl_file.c:#define MAX_VOL_SLICES 4
gvl_file.c:#define MAX_VOL_FILES 100
I feel that MAX_VOL_SLICES and MAX_VOL_FILES should probably go into
gsurf.h and that MAX_VOLS should match MAX_VOL_FILES.
