[GRASS5] [bug #3153] (grass) v.in.garmin waypoint import
this bug's URL: http://intevation.de/rt/webrt?serial_num=3153
Subject: v.in.garmin waypoint import
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
GRASS Version: 6.0 release
The waypoint-import works fine for LL-locations.
If a UTM-location is used, there's a problem about the database:
v.in.garmin -v -w out=tafelnX port=/dev/ttyS0
---------snip----------------------------------
Uploading Waypoints
Coordinate format: DDD
Attempting waypoint projection transform with cs2cs
Importing Waypoints...
Maximum input row length: 0
Maximum number of columns: 0
Minimum number of columns: -1
ERROR: x column number > minimum last column number
<tafelnX> columns:
DBMI-DBF driver error:
Table 'tafelnX' doesn't exist
Done.
Peter
Uploading Waypoints
<tafelnX> columns:
Done.
can you try without setting the output= option? then it will send
data to stdout and you can see why v.in.ascii is unhappy.
doesn't look like any data is getting there.
You might try commenting out the "rm" line at the end of the file and
then looking at the bits left over in $MAPSET/.tmp/$HOST/ to see how
far the data makes it.
note: known bug (unreleated), db link must be set with db.connect
before using the module; if DBF, then a $MAPSET/dbf/ dir must exist
too? [haven't tested in a while]
Hamish
I tested yesterday: yes, the $MAPSET/dbf/ dir must be created manually.
Let me propose to automate that for dbf... but no idea where.
manually. Let me propose to automate that for dbf... but no idea
where.
Waypoint mode (or with -p flag) should create/link as needed with
v.in.ascii format=point
as needed (I think..?).
But when the script makes track or route lines with:
v.in.ascii format=standard
it does not create a table; the script creates one by hand with
echo "CREATE TABLE ..." | db.execute
  [this step needs db to be set]
then populate the table it with
echo "INSERT INTO ..." | db.execute
then links with v.db.connect.
So it is hard to see what could be automated to create & link dbf/.
Maybe a test for $MAPSET/dbf and 'db.connect -p' before CREATE TABLE
in the v.in.garmin script is correct after all and no automation?
Hamish
