[GRASS5] [bug #3160] (grass) r.support build error
this bug's URL: http://intevation.de/rt/webrt?serial_num=3160
Subject: r.support build error
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
GRASS Version: cvs_18_04_05
GRASS GIS compilation log
Started compilation: pon kwi 18 21:16:20 CEST 2005
Errors in:
/home/pingwin/src/grass6/raster/r.support/modcats
/home/pingwin/src/grass6/raster/r.support/modhist
Finished compilation: pon kwi 18 21:26:31 CEST 2005
(In case of errors please change into the directory with error and run 'make')
   So I did:
[pingwin@localhost r.support]$ make
modcats
make[1]: Entering directory `/home/pingwin/src/grass6/raster/r.support/modcats'
Makefile:15: ostrze¿enie: polecenia zakrywaj±ce dla obiektu `htmletc1'
../../../include/Make/Rules.make:94: ostrze¿enie: ignorujê stare polecenia dla obiektu `htmletc1'
gcc -s -pipe -D_FILE_OFFSET_BITS=64 -Wl,--export-dynamic -L/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/lib -DPACKAGE=\""grassmods"\" -o /home/pingwin/src/grass6/dist.i686-pc-linux-gnu/etc/modcats OBJ.i686-pc-linux-gnu/modcats.o -lgrass_gis -lgrass_datetime -lz -lgrass_edit -lm -lz
/usr/bin/ld: warning: libgrass_vask.so, needed by /home/pingwin/src/grass6/dist.i686-pc-linux-gnu/lib/libgrass_edit.so, not found (try using -rpath or -rpath-link)
/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/lib/libgrass_edit.so: undefined reference to `V_ques'
/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/lib/libgrass_edit.so: undefined reference to `V_line'
/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/lib/libgrass_edit.so: undefined reference to `V_call'
/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/lib/libgrass_edit.so: undefined reference to `V_intrpt_ok'
/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/lib/libgrass_edit.so: undefined reference to `V_const'
/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/lib/libgrass_edit.so: undefined reference to `V_clear'
collect2: ld returned 1 exit status
make[1]: *** [/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/etc/modcats] B³±d 1
make[1]: Leaving directory `/home/pingwin/src/grass6/raster/r.support/modcats'
modcolr
make[1]: Entering directory `/home/pingwin/src/grass6/raster/r.support/modcolr'
No docs to generate.
echo "<HR>" >> modcolr.tmp.html
#generate module class reference:
echo "</body></html>" >> modcolr.tmp.html
mkdir -p /home/pingwin/src/grass6/dist.i686-pc-linux-gnu/docs/html
mv -f modcolr.tmp.html /home/pingwin/src/grass6/dist.i686-pc-linux-gnu/docs/html/modcolr.html
/usr/bin/install -c *.png *.jpg /home/pingwin/src/grass6/dist.i686-pc-linux-gnu/docs/html 2> /dev/null ; true
mkdir -p /home/pingwin/src/grass6/dist.i686-pc-linux-gnu/etc/support
/usr/bin/install -c -m 755 /home/pingwin/src/grass6/dist.i686-pc-linux-gnu/etc/modcolr /home/pingwin/src/grass6/dist.i686-pc-linux-gnu/etc/support
make[1]: Leaving directory `/home/pingwin/src/grass6/raster/r.support/modcolr'
modhist
make[1]: Entering directory `/home/pingwin/src/grass6/raster/r.support/modhist'
Makefile:15: ostrze¿enie: polecenia zakrywaj&#177;ce dla obiektu `htmletc1'
gcc -s -pipe -D_FILE_OFFSET_BITS=64 -Wl,--export-dynamic -L/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/lib -DPACKAGE=\""grassmods"\" -o /home/pingwin/src/grass6/dist.i686-pc-linux-gnu/etc/modhist OBJ.i686-pc-linux-gnu/modhist.o -lgrass_gis -lgrass_datetime -lz -lgrass_edit -lm -lz
make[1]: *** [/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/etc/modhist] B³&#177;d 1
make[1]: Leaving directory `/home/pingwin/src/grass6/raster/r.support/modhist'
modhead
make[1]: Entering directory `/home/pingwin/src/grass6/raster/r.support/modhead'
echo "<HR>" >> modhead.tmp.html
echo "</body></html>" >> modhead.tmp.html
mv -f modhead.tmp.html /home/pingwin/src/grass6/dist.i686-pc-linux-gnu/docs/html/modhead.html
/usr/bin/install -c -m 755 /home/pingwin/src/grass6/dist.i686-pc-linux-gnu/etc/modhead /home/pingwin/src/grass6/dist.i686-pc-linux-gnu/etc/support
make[1]: Leaving directory `/home/pingwin/src/grass6/raster/r.support/modhead'
front
make[1]: Entering directory `/home/pingwin/src/grass6/raster/r.support/front'
GISRC=/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/demolocation/.grassrc61 GISBASE=/home/pingwin/src/grass6/dist.i686-pc-linux-gnu PATH=/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/bin:$PATH LD_LIBRARY_PATH="/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/lib:" /home/pingwin/src/grass6/dist.i686-pc-linux-gnu/bin/r.support --html-description | grep -v '</body>' > r.support.tmp.html ; true
echo "<HR>" >> r.support.tmp.html
echo "</body></html>" >> r.support.tmp.html
mv -f r.support.tmp.html /home/pingwin/src/grass6/dist.i686-pc-linux-gnu/docs/html/r.support.html
make[1]: Leaving directory `/home/pingwin/src/grass6/raster/r.support/front'
gcc 3.4.1 if it matters
Maciek
Errors in:
   So I did:
modcats
Please do:
  LANG=C make
to get error messages in English.
Errors in:
   So I did:
modcats
Please do:
LANG=C make
It didn't change the language that make's output speaks. Other suggestions?
Maciek
>> Errors in:
>> 'make')
>> So I did:
>> modcats
>> `htmletc1'
> Please do:
> LANG=C make
just tell us what it is saying when the errors start?
Hamish
>> Errors in:
>> 'make')
>> So I did:
>> modcats
>> `htmletc1'
> Please do:
> LANG=C make
Makefile:15: warning: covering instructions for object `htmletc1'
../../../include/Make/Rules.make:94: warning: ignoring old instructions for object `htmletc1'
Any good?
Maciek
>> Errors in:
>> 'make')
>> So I did:
>> modcats
>> `htmletc1'
> Please do:
> LANG=C make
Sorry; I should have suggested:
  LC_ALL=C make
LC_ALL overrides the individual LC_* variables (e.g. LC_MESSAGES),
while LANG provides a default for any which aren't set.
object `htmletc1'
Any good?
That's just a warning, and is expected. It won't cause the build to
fail.
LC_ALL=C make
Now it speaks English:
modcats
Makefile:15: warning: overriding commands for target `htmletc1'
../../../include/Make/Rules.make:94: warning: ignoring old commands for target `htmletc1'
make[1]: *** [/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/etc/modcats] Error 1
modcolr
modhist
make[1]: *** [/home/pingwin/src/grass6/dist.i686-pc-linux-gnu/etc/modhist] Error 1
modhead
front
> LC_ALL=C make
modcats
target `htmletc1'
-lm -lz
Right. As it says, we should be using -rpath-link. I thought that we
were.
The correct switches are already present in LD_SEARCH_FLAGS, but we
don't appear to be using that.
AFAICT, the way that other modules get around this is to explicitly
add $(VASKLIB) to the link command in the Makefile.
> -lm -lz
were.
... if you know how to fix that, please apply to the CVS.
Thanks
> > -lm -lz
> were.
Done.
BTW, I've noticed that LDFLAGS includes $(PQLIBPATH), although it
doesn't belong there.
> > > -lm -lz
> > were.
Done.
Thanks.
Should it be fixed by removing it or in a different way?
I'm not sure. Ultimately, it should be removed, but that may require
it to be added somewhere else; I wouldn't know where.
