this bug's URL: http://intevation.de/rt/webrt?serial_num=3161
Subject: inability to import shape files using v.in.ogr
Platform: Mac OSX
grass obtained from: Trento Italy site
grass binary for platform: Downloaded precompiled Binaries
GRASS Version: 6.0.0
Please enter your name and error description here
From Brian Beckage:
I have had been unable to import a vector file (using v.in.ogr) of the Everglades coastline in Florida,
USA. The coastline is very irregular with many small islands. My machine worked on this for three
days, and appeared to be making very slow progress (e.g., the line number at the bottom of the
output shown below keeps increasing), albeit slowly. I estimated that it would take about a week to
complete this import. I'm using Grass 6.0.0 on Mac OSX 10.3.8 (1GHZ, 1 GB RAM) and the output is
displayed below. I've had to kill the process.
v.in.ogr dsn=/Users/PROJECTS/ENP/Plot_Info/GIS/PaulsCD/k24bound.shp output=k24bound
A datum name nad27 (North_American_Datum_1927) was specified without transformation
parameters.
WARNING: Non-interactive mode: the GRASS default for nad27 is
towgs84=-22.000,157.000,176.000.
Projection of input dataset and current location appear to match.
Proceeding with import...
Layer: k24bound
Building topology ...
18233 primitives registered
Building areas: 100%
18233 areas built
18233 isles built
Attaching islands: 100%
Attaching centroids: 100%
Topology was built.
Number of nodes : 18233
Number of primitives: 18233
Number of points : 0
Number of lines : 0
Number of boundaries: 18233
Number of centroids : 0
Number of areas : 18233
Number of isles : 18233
Number of areas without centroid : 18233
WARNING: Cleaning polygons, result is not guaranteed!
Topology was built.
Number of lines : 0
Number of areas : -
Number of isles : -
Break polygons:
Registering points ... 745775
All points (vertices): 764031
Registered points (unique coordinates): 745775
Points marked for break: 18254
Breaks: 65
Remove duplicates:
Duplicates: 0
Break boundaries:
Intersections: 297999 (line 89173)
