this bug's URL: http://intevation.de/rt/webrt?serial_num=3165
Subject: v.db.select: multiple support for column=
Platform: GNU/Linux/i386
grass obtained from: Mirror of Trento site
GRASS Version: 6.1cvs April 2005
the new column= option for v.db.select is nice, but it would be great if you could use it to list multiple columns, e.g.
v.db.select map col=ID,NAME
thanks,
Hamish
Done. Was a single line code addition
Please test.
Example:
v.db.select roads col=label,cat
label|cat
no data|0
interstate|1
primary highway, hard surface|2
secondary highway, hard surface|3
light-duty road, improved surface|4
unimproved road|5
