[GRASS5] [bug #3170] (grass) v.label help mentions p.map, which is gone
this bug's URL: http://intevation.de/rt/webrt?serial_num=3170
v.label help mentions p.map, which is gone.
d.paint.labels help also mentions some p things.
g.manual v.label doesn't say what d program one uses to display the labels.
And this probably is busted these days:
v.label -a map=contourtest5 column=level labels=contourtest8
Labeled 57 lines.
d.paint.labels labels=contourtest8
Error: rotate: 15.924559...
Without the -a the error messages are gone, but it just draws circles on
the monitor, just the same.
P.S.
v.out.ascii contourtest5 out=contourtest99
find ~jidanni/tmp/grassdata -cmin -1
doesn't find anything, nor does -mmin, i.e., v.out.ascii doesn't do anything anymore.
g.version
GRASS 6.0.0beta2 (2005)
--- Headers Follow ---
From jidanni@jidanni.org Wed Apr 20 23:34:10 2005
Return-Path: <jidanni@jidanni.org>
Delivered-To: grass-bugs@lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
  by lists.intevation.de (Postfix) with ESMTP id 4D4301006B3
  for <grass-bugs@lists.intevation.de>; Wed, 20 Apr 2005 23:34:10 +0200 (CEST)
Received: from localhost (localhost [127.0.0.1])
  by mail.intevation.de (Postfix) with ESMTP id C745C36CDD
  for <grass-bugs@lists.intevation.de>; Wed, 20 Apr 2005 23:34:09 +0200 (CEST)
Received: from frodo.hserus.net (frodo.hserus.net [204.74.68.40])
  by mail.intevation.de (Postfix) with ESMTP id 1B43A36CDB
  for <grass-bugs@intevation.de>; Wed, 20 Apr 2005 23:34:09 +0200 (CEST)
Received: from tc218-187-66-206.2-1.dynamic.apol.com.tw ([218.187.66.206]:32850 helo=jidanni1)
  by frodo.hserus.net with esmtpsa
  (Cipher TLSv1:AES256-SHA:256) (Exim 4.50 #1)
  id 1DOMph-0007xT-Vu by authid <jidanni> with plain
  for <grass-bugs@intevation.de>; Thu, 21 Apr 2005 03:04:06 +0530
To: grass-bugs@intevation.de
Subject: v.label help mentions p.map, which is gone
Date: Wed, 20 Apr 2005 10:39:57 +0800
Message-ID: <87r7h66uiq.fsf@jidanni.org>
MIME-Version: 1.0
Content-Type: text/plain; charset=us-ascii
X-Spam-Status: No, hits=-4.2 tagged_above=-999.0 required=3.0 tests=BAYES_00,
  DATE_IN_PAST_12_24
X-Spam-Level:
