this bug's URL: http://intevation.de/rt/webrt?serial_num=3171
Subject: saved state for windows positions
Platform: GNU/Linux/i386
grass obtained from: CVS
GRASS Version: 6.1 cvs
Carlos H Grohmann - IGc-USP - Brazil
In GRASS 5.4, when you ended a session, you could save the state of all windows, so when you started a new session, all would be in the same place. That's not what happens in 6.0/6.1. Every time you start a session, the display manager starts in the cernert of the screen, and if you had left some windows opened the last time you used it (like your most used commands) they won't be there either. Can it be done?
