[GRASS5] [bug #3172] (grass) d.where -l is giving wrong results
this bug's URL: http://intevation.de/rt/webrt?serial_num=3172
Subject: d.where -l is giving wrong results
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
GRASS Version: grass61_13_04_05_1052
Seems a serious one but I didn't dare to "critical" it.
I have a following mapset:
GRASS 6.1.cvs (caves_utm33):~ > g.proj -p
-PROJ_INFO-------------------------------------------------
name : Universe Transverse Mercator
proj : utm
datum : wgs84
a : 6378137
es : 0.0066943800
zone : 33
no_defs : defined
-PROJ_UNITS------------------------------------------------
unit : metre
units : metres
meters : 1
GRASS 6.1.cvs (caves_utm33):~ > g.region -p
projection: 1 (UTM)
zone: 33
datum: wgs84
ellipsoid: a=6378137 es=0.00669438
north: 5724924
south: 5724724
west: 572360
east: 572688
nsres: 1
ewres: 1
rows: 200
cols: 328
When query point's coordinates with d.where, I'm getting different results whether switch -l or -w is used:
d.where -l
EAST: NORTH: LON: LAT:
        572500.425 5724830.725 16:02:54.226371E 51:40:11.746412N
d.where -w
WGS84 Co-ordinates
        572500.425 5724830.725 16:02:54.226371E 51:40:11.179813N
It looks that "-l" is wrong, because cs2cs gives the same as "-w":
trawiarz@quercus trawiarz]$ echo "572500.425 5724830.725" | cs2cs +proj=utm +zone=33 +to +proj=latlong +ellps=WGS84
16d2'54.226"E 51d40'11.18"N 0.000
That's quite a difference: 17.51m N and 0.25m E.
Maciek
