[GRASS5] [bug #3179] (grass) say how to delete mapsets too
this bug's URL: http://intevation.de/rt/webrt?serial_num=3179
g.mapset should in SEE ALSO refer to how to also remove mapsets.
P.S., 'g.setproj help' does not help, but instead executes. i.points help too.
On g.setproj's man page, NAME is repeated twice.
On i.points's man page, NAME is empty.
P.S., When one starts up one sees:
$ grass
                            GRASS 6.0.0beta2
   LOCATION: This is the name of an available geographic location. -spearfish-
          is the sample data base for which all tutorials are written.
** all tutorials?!
   MAPSET: Every GRASS session runs under the name of a MAPSET.
      Associated with each MAPSET is a rectangular COORDINATE
      REGION and a list of any new maps created.
However, in g.gisenv.html we see "Maps stored under the same GRASS
LOCATION_NAME (and/or within the same MAPSET) must use the same
coordinate system"
Therefore the boilerplate upon starting grass is misleading.
So instead of talking about spearfish, mention coordinate systems, or
else one will think to use a different geoid, one just needs a
different mapset, or something.
--- Headers Follow ---
From jidanni@jidanni.org Sat Apr 23 00:24:43 2005
Return-Path: <jidanni@jidanni.org>
Delivered-To: grass-bugs@lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
  by lists.intevation.de (Postfix) with ESMTP id 72E0A1005D7
  for <grass-bugs@lists.intevation.de>; Sat, 23 Apr 2005 00:24:43 +0200 (CEST)
Received: from localhost (localhost [127.0.0.1])
  by mail.intevation.de (Postfix) with ESMTP id 473EF36CDC
Received: from frodo.hserus.net (frodo.hserus.net [204.74.68.40])
  by mail.intevation.de (Postfix) with ESMTP id 970F336CDB
  for <grass-bugs@intevation.de>; Sat, 23 Apr 2005 00:24:41 +0200 (CEST)
Received: from tc218-187-81-241.2-7.dynamic.apol.com.tw ([218.187.81.241]:33067 helo=jidanni1)
  by frodo.hserus.net with esmtpsa
  (Cipher TLSv1:AES256-SHA:256) (Exim 4.50 #1)
  id 1DP6Zj-0005vh-6O by authid <jidanni> with plain
  for <grass-bugs@intevation.de>; Sat, 23 Apr 2005 03:54:40 +0530
To: grass-bugs@intevation.de
Subject: say how to delete mapsets too
Date: Sat, 23 Apr 2005 03:33:57 +0800
Message-ID: <87mzrq8v2x.fsf@jidanni.org>
MIME-Version: 1.0
Content-Type: text/plain; charset=us-ascii
X-Spam-Status: No, hits=-4.9 tagged_above=-999.0 required=3.0 tests=BAYES_00
X-Spam-Level:
