[GRASS5] [bug #3246] (grass) d.vect.thematic fails when the map is in another mapset
this bug's URL: http://intevation.de/rt/webrt?serial_num=3246
Subject: d.vect.thematic fails when the map is in another mapset
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
GRASS Version: grass61_cvs_2005_05_16
Michael
The map 'gminy_zw' is in mapset 'robot'. When displayed with d.vect.thematic from within the 'robot' mapset all is OK. But when from another mapset d.vect.thematic fails:
d.vect.thematic 'themetype=graduated colors' themecalc=interval map=gminy_zw@robot column=KK layer=1 type=area icon=basic/circle size=5 maxsize=20 nint=4 colorscheme=red-blue singlecolor=red
dbmi: Protocol error
awk: cmd. line:1: (FILENAME=- FNR=1) fatal: division by zero attempted
Thematic map legend for column KK of map gminy_zw@robot
Value range: -
Mapped by 4 intervals of
Color(R:G:B) Value
250:0:0 >0 - 0
BTW - can the colortable be stored in GRASSRGB column? I guess you where discussing this on the list but I can't find the option in d.vect.thematic.
Many thanks for this module, I'm sure it will be usefull for many of us.
Maciek
I think this was fixed in the update I posted today.
Michael
______________________________
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
Reply-To: Request Tracker <grass-bugs@intevation.de>
Date: Mon, 16 May 2005 16:32:14 +0200 (CEST)
To: <grass5@grass.itc.it>
Subject: [GRASS5] [bug #3246] (grass) d.vect.thematic fails when the map is in
another mapset
Michael
Value range: -
Color(R:G:B) Value
250:0:0 >0 - 0
Maciek
fine, I'll check it tomorrow
thank you
Maciek
----- Original Message ----- From: "Michael Barton" <michael.barton@asu.edu>
To: "Paolo Cavallini via RT" <grass-bugs@intevation.de>; <grass5@grass.itc.it>
Sent: Monday, May 16, 2005 10:08 PM
Subject: Re: [GRASS5] [bug #3246] (grass) d.vect.thematic fails when the map is in another mapset
Michael
USA
another mapset
Michael
Value range: -
Color(R:G:B) Value
250:0:0 >0 - 0
Maciek
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
