[GRASS5] [bug #3246] (grass) d.vect.thematic fails when the map is in another mapset
sorry for this doubled post Michael - I forgot to CC the grass5 list the
previous time
Michael
Unfortunatelly the bug remains - it is impossible to use d.vect thematic on a
map which is not in the same mapset where the session was started. There is
always " Table '(...)' doesn't exist." information. Could you please try to
fix it?
The GRASSRGB switch works like a charm. Thanks!
But there is incostistency in the legend provided by d.vect.thematic -l:
Value range: 57.920000 - 69.400000
Mapped by 1 intervals of 11.5948
Color(R:G:B) Value
250:0:0 >57.3408 - 69.5148
As you can see the calculated "Value range" is different than in the legend's
"Value" column. No matter what interval is used (here nint=1) there is always
a difference. Could it be fixed too?
Also I think that the ">" sign between the color and the the value in the
legend should be removed - it doesn't help in anything and worsens the clarity
of the information. How do you think?
Maciek
1. This math interval difference only happens for the first interval
(min-value) for invterval mapping. This is to make sure that ALL values are
included and each value is included only once. If I specify [>lower value
and <= higher value] for each interval, I miss the minimum value of the
total range. If I specify [>=lower value and <=higher value] for each range,
some values get counted twice. So the actual range of values mapped is
correct, but the lower value shown in the legend is slightly below the
actual minimum. The "11.5948" instead of "11.60" is some kind of internal
rounding error that I have no idea how to correct.
2. I use the notation >lower value - higher value because of several
requests by users to do so. This makes it clearer that the interval is
greater (i.e., not inclusive of) the minimum and less than or equal to
(i.e., inclusive of) the maximum.
Michael
______________________________
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
From: Maciek Sieczka via RT <grass-bugs@intevation.de>
Reply-To: Maciek Sieczka via RT <grass-bugs@intevation.de>
Date: Tue, 17 May 2005 17:59:21 +0200 (CEST)
Cc: <grass5@grass.itc.it>, <michael.barton@asu.edu>
Subject: [bug #3246] (grass) d.vect.thematic fails when the map is in another
mapset
previous time
Michael
fix it?
Color(R:G:B) Value
Maciek
Actually it also happens for the last interval too - max in the legend and
the actual max are never the same. Is it also by design?
range,
Michael
Understood. But anyway if I use the d.vect.thematic -l output for
publication it may look supsicious for the eventual reader. I'm not
complaining here - I rerally apprecaite your effort and just trying to be helpfull. This legend looks suspicious and if somebody could fix it would great.
And what about the bug remaining (as in the title)? Any chances it will be
fixed?
Maciek
USA
another
mapset
previous time
Michael
on a
is
to
fix it?
Color(R:G:B) Value
legend's
always
clarity
Maciek
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Maciek,
I fixed the problem with d.vect.thematic not working with maps from a
different mapset. I think I've also improved the interval thematic mapping.
Please check out the newest version I just committed to the cvs and posted
to my website.
I tend to agree with you that
min - max
looks better than
min - max
although the second one is more accurate.
What does everyone else think?
Michael
USA
Date: Thu, 19 May 2005 19:39:31 +0200
To: Michael Barton <michael.barton@asu.edu>, Paolo Cavallini via RT
Cc: grass devel <grass5@grass.itc.it>
Subject: Re: [GRASS5] Re: [bug #3246] (grass) d.vect.thematic fails when the
range,
Michael
great.
fixed?
Maciek
USA
another
mapset
previous time
Michael
on a
is
to
fix it?
Color(R:G:B) Value
legend's
always
clarity
Maciek
grass5 mailing list
grass5@grass.itc.it
Sent: Fri, 20 May 2005 10:12:41 -0700
min - max
looks better than
>min - max
I'd like the math standard :
[min ; cut1]
]cut1 ; cut2]
]cutn ; max]
Note the *included* min. I'll see if I can put that into your current script,
Michael.
Daniel.
If you want to change your local version, please go right ahead and see how
it looks.
Let's not change the cvs version until we have a consensus (if possible).
For work in my field (archaeology) and from what I know of geography, the
notation
]min ; max]
would be meaningless--although it might be perfect for your field
Michael
USA
Reply-To: <daniel.calvelo@minag.gob.pe>
Date: Fri, 20 May 2005 12:22:08 -0500
To: Michael Barton <michael.barton@asu.edu>, Maciek Sieczka
<werchowyna@epf.pl>, Paolo Cavallini via RT <grass-bugs@intevation.de>
min - max
looks better than
min - max
[min ; cut1]
]cut1 ; cut2]
]cutn ; max]
Michael.
Daniel.
Michael,
I would like to play with d.vect.thematic. I have installed Lorenzo Moretti's GRASS distribution for Mac OS X for both 5.4 & 6.0 and use both. What do I need to do to try it out? Thanks for your help.
Tom
it looks.
notation
]min ; max]
Michael
USA
min - max
looks better than
min - max
[min ; cut1]
]cut1 ; cut2]
]cutn ; max]
Michael.
Daniel.
grass5 mailing list
grass5@grass.itc.it
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL: thomas.adams@noaa.gov
VOICE: 937-383-0528
FAX: 937-383-0033
I'm on MacOSX right now. Quick and dirty, since "." is in the PATH:
1. Unpack Michael's thematic.tgz;
2. start grass (I use 6);
3. within grass cd to the thematic/d.vect.thematic directory;
4. issue a 'cp ../v.univar.sh/v.univar.sh .'
5. presto.
You won't see colors in the graphical legend, though (you need CVS for that).
Daniel
-- Daniel Calvelo Aros
---------- Original Message -----------
Cc: grass5@grass.itc.it
Sent: Fri, 20 May 2005 14:07:20 -0400
Subject: [GRASS5] d.vect.thematic on Mac OS X
Michael,
LorenzoMoretti's GRASS distribution for Mac OS X for both 5.4 & 6.0
anduse both. What do I need to do to try it out? Thanks for your help.
Tom
see how it looks.
possible). For work in my field (archaeology) and from what I know
of geography, the notation
]min ; max]
Michael
USA
bugs@intevation.de> Cc: grass devel <grass5@grass.itc.it> Subject:
min - max
looks better than
min - max
[min ; cut1]
]cut1 ; cut2]
]cutn ; max]
current script, Michael.
Daniel.
grass5 mailing list
grass5@grass.itc.it
Thomas E Adams
VOICE: 937-383-0528
FAX: 937-383-0033
------- End of Original Message -------
Sent: Fri, 20 May 2005 10:39:53 -0700> If you want to change your local
see how it looks.
]min ; max]
Ok, let's wait for things to settle. I attach a heavily overhauled version of
d.vect.thematic that does the following:
- takes care of the min included (it *is* in the first interval)
- is prepared for any bracketing needed, but uses the "a - b" notation currently
- solves the problem of using stdevs and having eg. min>mean-2stdev
The code, though, is much shorter since I've changed the way the script is
architectured. That's why I send it in toto instead of patch:
- I added an (internal, e.g. not accesible to users) "annotation" facility,
which miught be important for stdev-type classifications.
- I've factored all the query draw and print sections to work from a set of
breakpoint definitions, which are calculated differently for each of the
themecalc methods. It complicates thing a little but it allows for easier
classifier additions later, and is less cumbersome for further enhancements
(only one spot for changes).
- I've left the points part alone, since I don't have point data at hand to
test against, and I'd like your comments before refactoring further.
Please test and comment.
Daniel.
PS. this is not standalone as it still requires v.univar.sh
Michael
USA
> From: Daniel Calvelo Aros <dcalvelo@minag.gob.pe>
> From: Michael Barton <michael.barton@asu.edu>
>> min - max
>> looks better than
>>> min - max
> [min ; cut1]
> ]cut1 ; cut2]
> ]cutn ; max]
> Michael.
> Daniel.
grass5 mailing list
grass5@grass.itc.it
(attachments)
d.vect.thematic.dca (29.8 KB)
Thanks Daniel.
Here is a more "Mac" way to install it.
This assumes that you are using Lorenzo Moretti's Mac binaries.
1. Go to your grass folder (in Applications).
2. Select the GRASS program file. I did this for grass61cvs, but it should
work for grass60 also.
3. Hold down the control key and click with the mouse (or right click on a
3-button mouse).
4. Select "Show package contents"
5. Navigate to Contents/Resources/grass-6.1cvs/scripts (or
.../grass-6.0/scripts)
6. Put d.vect.thematic and v.univar.sh in the scripts folder
7. Voila, you can run them from the GRASS command line (I'll add them to the
GIS Manager menu soon).
Note that sometimes the execute permission gets turned off when these files
travel across the ether. You can not turn this on via the Mac "get info"
dialog for some weird reason. You can either use the chmod command from the
terminal to do this or download a nifty utility called BatChmod from
www.versiontracker.com that will allow you to set the execute permissions.
Michael
USA
Date: Fri, 20 May 2005 14:22:50 -0500
To: Thomas Adams <Thomas.Adams@noaa.gov>, Michael Barton
Subject: Re: [GRASS5] d.vect.thematic on Mac OS X
5. presto.
Daniel
Michael,
Tom
see how it looks.
]min ; max]
Michael
USA
min - max
looks better than
min - max
[min ; cut1]
]cut1 ; cut2]
]cutn ; max]
Daniel.
grass5 mailing list
grass5@grass.itc.it
Thomas E Adams
VOICE: 937-383-0528
FAX: 937-383-0033
Daniel,
I tried out your code changes to d.vect.thematic.
There were a few odd display glitches, but overall it worked well.
I've gone ahead and rewritten the graduated points routine along the lines
of your graduated colors routine. It revealed a problem I didn't notice
previously with the graduated points, so I fixed it. I made a couple of
other improvements to the points legend.
I also added a flag option for math notation brackets, so everyone should be
happy (or at least happier).
Could you try it out and see what you think? If you want to test the
graduated point routine, just use areas and select centroids as the vector
type.
Lorenzo Moretti suggested an option to write out the thematic mapping as a
group file for the GIS Manager. This is intriguing and I might try to add
this in the next update if there is some interest.
Michael
see how it looks.
]min ; max]
currently
Daniel.
Michael
USA
min - max
looks better than
min - max
[min ; cut1]
]cut1 ; cut2]
]cutn ; max]
script,
Michael.
Daniel.
grass5 mailing list
grass5@grass.itc.it
C. Michael Barton, Professor of Anthropology
PO Box 872402
USA
Phone: 480-965-6262
Fax: 480-965-7671
(attachments)
d.vect.thematic (18.9 KB)
Michael & Daniel,
Thanks for your help!
Tom
Thanks Daniel.
3-button mouse).
Michael
USA
5. presto.
Daniel
Michael,
Tom
see how it looks.
]min ; max]
Michael
USA
min - max
looks better than
min - max
[min ; cut1]
]cut1 ; cut2]
]cutn ; max]
Daniel.
grass5 mailing list
grass5@grass.itc.it
Thomas E Adams
VOICE: 937-383-0528
FAX: 937-383-0033
Thomas E Adams
VOICE: 937-383-0528
FAX: 937-383-0033
On Sun, May 22, 2005 18:49, Michael Barton said:
Daniel,
Here both versions (your's and Daniel's) work fine.
The graduated points legend only displays boxes, even when I chose other
symbols. Is this normal ?
Yes, this seems like the best solution to me.
Sounds good. This would allow using the GIS Manager print command to print the
results to a ps file.
Thanks a lot to both of you for the great work !
Moritz
Yes. I'm using d.graph to create the legend. Currently, it only allows the
old GRASS 5 default (with o displaying as an open box). With Hamish's update
to d.graph, it will display the box in the selected color. Perhaps, it is
possible to update d.graph to show the new GRASS 6 icons?
Michael
Moritz
PO Box 872402
USA
Phone: 480-965-6262
Fax: 480-965-7671
