this bug's URL: http://intevation.de/rt/webrt?serial_num=3271
Subject: r.out.gdal should use gdalwarp instead of gdal_translate
Platform: GNU/Linux/i386
grass obtained from: Other (CDROM etc)
grass binary for platform: Downloaded precompiled Binaries
r.out.gdal script should use gdalwarp instead of gdal_translate to offer the same expected feature than other r.out.* functions. The output raster should have the extent and resolution of the current region. A specific flag could be add to activate or desactivate this feature.
I don't think that it should gdalwarp.
To solve the problem, you need to update your GDAL installation. Recently the GRASS/GDAL
plugin was updated to respect the current region settings.
However, this change is in GDAL-CVS, so you either need to get a CVS snapshot or
wait for the next GDAL release.
