this bug's URL: http://intevation.de/rt/webrt?serial_num=3277
Subject: d.vect.thematic fails with DOUBLE
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
GRASS Version: cvs_25_05_05
d.vect.thematic works fine with INTEGER but fails with DOUBLE as follows:
d.vect.thematic map=gminy_zw_2003_prc_dem 'themetype=graduated colors' themecalc=interval column=PROD layer=1 type=area icon=basic/circle size=5 maxsize=20 nint=4 colorscheme=blue-red singlecolor=250:0:0 startcolor=250:0:0 endcolor=0:0:250 monitor=x1
awk: cmd. line:1: (FILENAME=- FNR=1) fatal: division by zero attempted
Thematic map legend for column PROD of map gminy_zw_2003_prc_dem
Value range: -
Mapped by 4 intervals of
Color(R:G:B) Value
0:0:250 . -
DBMI-DBF driver error:
SQL parser error in statement:
SELECT cat FROM gminy_zw_2003_prc_dem WHERE PROD >= and PROD<=
Error in db_open_select_cursor()
62:0:188 . -
SELECT cat FROM gminy_zw_2003_prc_dem WHERE PROD > and PROD<=
124:0:126 . -
186:0:64 . -
the vector file info:
GRASS 6.1.cvs (caves_utm33):~ > v.info gminy_zw_2003_prc_dem
| Layer: gminy_zw_2003_prc_dem Organization: |
| Mapset: admin Source Date: |
| Database: /home/grassdata |
| Title: |
| Map Scale: 1:1 |
| Map format: native |
| Type of Map: Vector (level: 2) |
| Number of points: 0 Number of areas: 23 |
| Number of lines: 0 Number of islands: 5 |
| Number of boundaries: 90 Number of faces: 0 |
| Number of centroids: 23 Number of kernels: 0 |
| Map is 3D: 0 |
| Number of dblinks: 1 |
| Projection: Universe Transverse Mercator (zone 33) |
| N: 5739296.326 S: 5660045.543 |
| E: 633165.320 W: 564573.435 |
| B: 0.000 T: 0.000 |
| Digitize threshold: 0.00000 |
| Comments: |
datbase info:
db.describe table=gminy_zw_2003_prc_dem driver=dbf database=$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
table:gminy_zw_2003_prc_dem
description:
insert:yes
delete:yes
ncols:14
column:CAT
description:
type:INTEGER
len:11
scale:0
precision:10
default:0
nullok:yes
select:yes
update:yes
column:NAZWA
description:
type:CHARACTER
len:15
scale:0
precision:0
default:
nullok:yes
select:yes
update:yes
column:PRZYR_PRC
description:
type:DOUBLE PRECISION
len:5
scale:2
precision:3
default:0.000000
nullok:yes
select:yes
update:yes
column:PRZEDPR
description:
len:8
scale:2
precision:6
default:0.000000
nullok:yes
select:yes
update:yes
column:PROD
description:
len:8
scale:2
precision:6
default:0.000000
nullok:yes
select:yes
update:yes
column:POPROD
description:
len:7
scale:2
precision:5
default:0.000000
nullok:yes
select:yes
update:yes
column:PRAC
description:
len:8
scale:2
precision:6
default:0.000000
nullok:yes
select:yes
update:yes
column:PRAC_ROL
description:
len:6
scale:2
precision:4
default:0.000000
nullok:yes
select:yes
update:yes
column:BEZR_REJ
description:
len:7
scale:2
precision:5
default:0.000000
nullok:yes
select:yes
update:yes
column:ZATR
description:
len:5
scale:2
precision:3
default:0.000000
nullok:yes
select:yes
update:yes
column:NIEZATR
description:
len:5
scale:2
precision:3
default:0.000000
nullok:yes
select:yes
update:yes
column:GESTOSC
description:
len:7
scale:2
precision:5
default:0.000000
nullok:yes
select:yes
update:yes
column:WIES_KM2
description:
len:4
scale:2
precision:2
default:0.000000
nullok:yes
select:yes
update:yes
column:grassrgb
description:
type:CHARACTER
len:11
scale:0
precision:0
default:
nullok:yes
select:yes
update:yes
Maciek
