In 5.4 there was a handy button for stopping/continuing operation of a module.
Could it be ported to 6.1? I found it very practical - say there is a
v.surf.rst working which eats whole my CPU time and it is going to work whole
day long, while I need full power just for 15 minutes for another Grass program.
I bet this could be done with some unix commands, but having that
stop/continue button was very usefull, easy and quick in use.
Maciek
module. Could it be ported to 6.1? I found it very practical - say
there is a v.surf.rst working which eats whole my CPU time and it is
going to work whole day long, while I need full power just for 15
fyi, the UNIX commands you speak of:
top
then hit "r" and type in PID of process eating 99% of the CPU. Set in
the range of 1-19, where 19 means the lowest priority.
Then "q" to quit.
or before starting the run reset the current shell's priority:
renice +19 -p $$
I add this to .grass.bashrc so GRASS always runs at semi-low priority:
GRASS_PROC="`pgrep Init.sh`"
if [ -n "$GRASS_PROC" ] ; then
renice +15 -p $$
fi
Thank you for this workaround. However, if possible, having stop/cont button
back would be very handy - one click instead of "top" and 4 keyboard
pressings (7 pressings alltogether) or "renice +19 -p $$" (17 pressings)
each time. Also modifying grass .grass.bashrc according to your listing will
be likely beyond knowledge of average Grass user, while everybody is capable
of using mouse.
I understand you wanted to help me and I'll make use of your suggestion,
thanks. However it would be wrong to take this as an ultimate solution for
all.
Maciek
top
Then "q" to quit.
renice +19 -p $$
renice +15 -p $$
fi
