[GRASS5] [bug #3342] (grass) many small v. and db. man page bugs
this bug's URL: http://intevation.de/rt/webrt?serial_num=3342
$ man v.to.db
DESCRIPTION
v.to.db load values from vector to database.
Add there "or report to stdout" or something, otherwise one needs to
read deep into the man page to find out v.to.db can do that.
$ man db.execute
       echo 'create table soils ("cat" int, "soiltype" text)' | db.execute
But the user will ask "I found I didn't need the double quotes".
SEE ALSO
       ...db.tables, GRASS SQL interface
You mean
       ...db.tables(1), sql(1).
$ man db.describe
Same problem as above, and also "GRASS 5.7 tutorial pages" embedded
into the man page. Best not to embed version numbers there.
$ man v.in.ascii
       columns=string
              Columns definition for points mode in SQL style, for example:
       x=integer
              Number of column used as x coordinate (first column is 1) for
              points mode. Default: 1
I there a missing example, or is x=integer part of it? The user can't
tell by the indentation...
Why the billion newlines?
$ man v.in.ascii |sed '/are as follows:/,$!d'|od -c|sed 's/[0-9 ]\+//g'
Theprimi
tivecodesarea
sfollows:\n\n\n\n\n\n
\n\n\n\n\n\n\n\n\n
Thecoordinates
$ man v.to.points
       v.to.points creates points along input lines.
OK, but also mention what ends up in the database files, just the
points created, or other previous things too. And what layers they
end up on.
$ man v.db.connect
   Connect vector map to database (PostgreSQL driver)
       db.describe -c map=vectormap <--Remove this whole line!
P.S.:
$ ls grassdata/shangcheng/addressing/dig_att
eeee kk
I must have made them somehow, but I can't list them with
g.list. I even tried:
IFS=, set -x rast,rast3d,vect,oldvect,asciivect,\
icon,labels,sites,region,region3d,group,3dview
set $@; for i do g.list type=$i;done
[Sorry once again to send fragments, but it takes about a minute to
send each email, so tough to fit into one modem call... will use
separate messages if more than just fragments...]
--- Headers Follow ---
From jidanni@jidanni.org Fri Jun 10 20:43:23 2005
Return-Path: <jidanni@jidanni.org>
Delivered-To: grass-bugs@lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
  by lists.intevation.de (Postfix) with ESMTP id 7129D101FB5
  for <grass-bugs@lists.intevation.de>; Fri, 10 Jun 2005 20:43:23 +0200 (CEST)
Received: from localhost (localhost [127.0.0.1])
  by mail.intevation.de (Postfix) with ESMTP id EFEEC36EA4
  for <grass-bugs@lists.intevation.de>; Fri, 10 Jun 2005 20:43:22 +0200 (CEST)
Received: from frodo.hserus.net (frodo.hserus.net [204.74.68.40])
  by mail.intevation.de (Postfix) with ESMTP id 8FD6636CE4
  for <grass-bugs@intevation.de>; Fri, 10 Jun 2005 20:43:20 +0200 (CEST)
Received: from [218.187.67.181] (port=32928 helo=jidanni1)
  by frodo.hserus.net with esmtpsa
  (Cipher TLSv1:AES256-SHA:256) (Exim 4.51 #0)
  id 1DgoT8-000FeR-DP by authid <jidanni> with plain
  for <grass-bugs@intevation.de>; Sat, 11 Jun 2005 00:13:18 +0530
To: grass-bugs@intevation.de
Subject: many small v. and db. man page bugs
Date: Sat, 11 Jun 2005 02:40:14 +0800
Message-ID: <87zmty9htd.fsf@jidanni.org>
MIME-Version: 1.0
Content-Type: text/plain; charset=us-ascii
X-Spam-Status: No, hits=-4.9 tagged_above=-999.0 required=3.0 tests=BAYES_00
X-Spam-Level:
$ man v.to.db
DESCRIPTION
$ man db.execute
SEE ALSO
You mean
AFAIK this was already fixed time ago.
$ man db.describe
Right, was already fixed.
$ man v.in.ascii
       columns=string
       x=integer
I don't understand the question.
Theprimi
tivecodesarea
\n\n\n\n\n\n\n\n\n
Thecoordinates
Looking at
g.manual -m v.in.ascii
it doesn't look too strange.
$ man v.to.points
end up on.
$ man v.db.connect
Why?
P.S.:
eeee kk
Since dig_att is usually not created in GRASS 6, it might be a residual
of GRASS 4/5 operations.
Sounds promising.
MIME-Version: 1.0
X-Spam-Level:
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
