[GRASS5] [bug #3346] (grass) WISH.. DXF to GRASS Vector
this bug's URL: http://intevation.de/rt/webrt?serial_num=3346
Subject: WISH.. DXF to GRASS Vector
grass obtained from: CVS
GRASS Version: GRASS6.1
Ravi Kumar, WISH
This is what we follow for
Scanned Map --> Raster -->DXF -->ARC-INFO Vector.. Wish it is possible for
Qcad dxf to GRASS vector also ..
There is a very quick method,
> 1. where all the digitization is done by the not so
> computer savvy draftsmen using Qcad.
> 2. Then the Geologist imports it into ARC-INFO (after the WISH to GRASS)to
> convert into a digital data with a vital link
> attribute. The attribute is an inscribed text of a link attribute in a polygon.
> 3. The geologist then attaches an external database
> table using this link attribute.
> If U can make such a thing possible in grass, then we
> can use OGLed Qcad on linux, for the draftsmen and
> GRASS for the Geologists.
