[GRASS5] [bug #3357] (grass) Build Errors in 6.1
this bug's URL: http://intevation.de/rt/webrt?serial_num=3357
Subject: Build Errors in 6.1
Platform: other
grass obtained from: CVS
GRASS Version: 6.1
./configure --with-proj-includes=/usr/local/lib
--with-tcltk-includes=/usr/local/lib --without-postgres --with-freetype
--with-gdal --with-x --enable-largefile --enable-64bit --enable-w11
--with-opengl-libs=/usr/X11R6/lib64
--with-freetype-includes=/usr/include/freetype2 --with-blas --with-cxx
then make results in:
Following modules are missing the 'description.html' file in src code:
v.parallel
v.split
GRASS GIS compilation log
Started compilation: Fri Jun 17 09:32:05 EDT 2005
Errors in:
/grass6/lib/gmath
/grass6/lib/imagery
/grass6/lib/rst/interp_float
/grass6/display/drivers/XDRIVER/XDRIVER24
/grass6/display/d.mon/pgms
/grass6/imagery/i.class
/grass6/imagery/i.cluster
/grass6/imagery/i.gensig
/grass6/imagery/i.gensigset
/grass6/imagery/i.group
/grass6/imagery/i.his.rgb
/grass6/imagery/i.maxlik
/grass6/imagery/i.ortho.photo/libes
/grass6/imagery/i.ortho.photo/menu
/grass6/imagery/i.ortho.photo/photo.2image
/grass6/imagery/i.ortho.photo/photo.2target
/grass6/imagery/i.ortho.photo/photo.camera
/grass6/imagery/i.ortho.photo/photo.elev
/grass6/imagery/i.ortho.photo/photo.init
/grass6/imagery/i.ortho.photo/photo.rectify
/grass6/imagery/i.ortho.photo/photo.target
/grass6/imagery/i.points
/grass6/imagery/i.rectify
/grass6/imagery/i.rgb.his
/grass6/imagery/i.smap/shapiro
/grass6/imagery/i.target
/grass6/imagery/i.vpoints
/grass6/imagery/i.cca
/grass6/imagery/i.fft
/grass6/imagery/i.ifft
/grass6/imagery/i.pca
/grass6/imagery/i.zc
/grass6/ps/ps.map
/grass6/raster/r.param.scale
/grass6/raster/r.resamp.rst
/grass6/raster/r.in.gdal
/grass6/raster/r.surf.fractal
/grass6/raster/r.surf.gauss
/grass6/raster/r.surf.random
/grass6/raster/r.terraflow
/grass6/vector/v.kernel
/grass6/vector/v.surf.rst
Finished compilation: Fri Jun 17 09:32:34 EDT 2005
(In case of errors please change into the directory with error and run
'make')
cd lib
make
/usr/bin/ld: cannot find -lgrass_gmath
collect2: ld returned 1 exit status
cd rst
make
make[1]: *** [/grass6/dist./lib/libgrass_interpfl.6.1.cvs.so] Error 1
make[1]: Leaving directory `/grass6/lib/rst/interp_float'
cd raster
make
cd ps
make
/usr/bin/ld: cannot find -lgrass_I
make[1]: *** [/grass6/dist./bin/ps.map] Error 1
make[1]: Leaving directory `/grass6/ps/ps.map'
...and so forth.
cd lib/gmath
make
gcc -shared -o
/grass6/dist.x86_64-unknown-linux-gnu/lib/libgrass_gmath.6.1.cvs.so
-Wl,--export-dynamic -L/grass6/dist.x86_64-unknown-linux-gnu/lib
-Wl,-rpath-link,/grass6/dist.x86_64-unknown-linux-gnu/lib
OBJ.x86_64-unknown-linux-gnu/brent.o OBJ.x86_64-unknown-linux-gnu/dalloc.o
OBJ.x86_64-unknown-linux-gnu/del2g.o OBJ.x86_64-unknown-linux-gnu/eigen.o
OBJ.x86_64-unknown-linux-gnu/eigen_tools.o
OBJ.x86_64-unknown-linux-gnu/fft.o OBJ.x86_64-unknown-linux-gnu/gauss.o
OBJ.x86_64-unknown-linux-gnu/getg.o OBJ.x86_64-unknown-linux-gnu/ialloc.o
OBJ.x86_64-unknown-linux-gnu/jacobi.o OBJ.x86_64-unknown-linux-gnu/la.o
OBJ.x86_64-unknown-linux-gnu/lu.o OBJ.x86_64-unknown-linux-gnu/max_pow2.o
OBJ.x86_64-unknown-linux-gnu/mult.o OBJ.x86_64-unknown-linux-gnu/rand1.o
OBJ.x86_64-unknown-linux-gnu/svd.o -lgrass_gis -lgrass_datetime -lz
-lfftw -lm && ln -sf libgrass_gmath.6.1.cvs.so
/grass6/dist.x86_64-unknown-linux-gnu/lib/libgrass_gmath.so
/usr/bin/ld: /usr/local/lib/libfftw.a(fftwnd.o): relocation R_X86_64_32
against `a local symbol' can not be used when making a shared object;
recompile with -fPIC
/usr/local/lib/libfftw.a: could not read symbols: Bad value
make: ***
[/grass6/dist.x86_64-unknown-linux-gnu/lib/libgrass_gmath.6.1.cvs.so]
Error 1
