[GRASS5] [bug #3377] (grass) r.mapcalc parsing error
this bug's URL: http://intevation.de/rt/webrt?serial_num=3377
Subject: r.mapcalc parsing error
G61 > r.mapcalc hilite='if(map3 < 0,1)'
ERROR: region for current mapset is not set
       run "g.region"
G61 > r.mapcalc hilite='if(map3 < 0,map3)'
100%
G61 >
[the region is fine]
Hamish
       run "g.region"
100%
G61 >
I think this was the Uint16 map with the 65535 color rules from the
previous bug. will re-test later.
Hamish
