[GRASS5] [bug #3398] (grass) ps.map: RGB support for points
this bug's URL: http://intevation.de/rt/webrt?serial_num=3398
Subject: ps.map: RGB support for points
vpoints lets the user select color by R:G:B or none.
points just lets you select by named color.
To fix we'd have to change the format of the plotting commands file. As this
seems to be an internal temp file I don't think it is a big deal WRT changing
things mid-release, but FYI..
Hamish
