this bug's URL: http://intevation.de/rt/webrt?serial_num=3417
Gentlemen, the below is a clear example of something that should be an
option for the user to decide: if he wants a border around his map or not!
How does one get ps.map to stop drawing a black border around
everything?
H> To get rid of the box around the map region you would need to edit the
H> source code or PostScript output as follows.
H> Comment out the following lines in ps/ps.map/ps_map.c and recompile.
H> /* put border around map */
H> fprintf(PS.fp, "BW\n");
H> box_draw(PS.map_top - 0.5, PS.map_bot + 0.5,
H> PS.map_left + 0.5, PS.map_right - 0.5);
H> or go towards the end of the PostScript file and find two lines
H> that look like this & delete them.
H> BW
H> 72.5 108.0 614.8 522.8 B D
--- Headers Follow ---
From jidanni@jidanni.org Wed Jul 13 23:32:09 2005
Return-Path: <jidanni@jidanni.org>
Delivered-To: grass-bugs@lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
by lists.intevation.de (Postfix) with ESMTP id 905151005DE
for <grass-bugs@lists.intevation.de>; Wed, 13 Jul 2005 23:32:09 +0200 (CEST)
Received: from localhost (localhost [127.0.0.1])
by mail.intevation.de (Postfix) with ESMTP id E1C8D36CE4
for <grass-bugs@lists.intevation.de>; Wed, 13 Jul 2005 23:32:00 +0200 (CEST)
Received: from frodo.hserus.net (frodo.hserus.net [204.74.68.40])
by mail.intevation.de (Postfix) with ESMTP id 49B0C36CE1
for <grass-bugs@intevation.de>; Wed, 13 Jul 2005 23:31:59 +0200 (CEST)
Received: from tc218-187-21-152.dialup.dynamic.apol.com.tw ([218.187.21.152]:32911 helo=jidanni1)
by frodo.hserus.net with esmtpsa
(Cipher TLSv1:AES256-SHA:256) (Exim 4.51 #0)
id 1Dsopd-0002pJ-Ka by authid <jidanni> with plain
for <grass-bugs@intevation.de>; Thu, 14 Jul 2005 03:01:56 +0530
To: grass-bugs@intevation.de
Subject: ps.map border should be optional!
References: <87fyuz2jyb.fsf@jidanni.org>
<20050701184751.05d1030c.hamish_nospam@yahoo.com>
Date: Thu, 14 Jul 2005 04:59:27 +0800
Message-ID: <878y0aqv68.fsf_-_@jidanni.org>
MIME-Version: 1.0
Content-Type: text/plain; charset=us-ascii
X-Spam-Status: No, hits=-4.9 tagged_above=-999.0 required=3.0 tests=BAYES_00
X-Spam-Level:
