[GRASS5] [bug #3432] (grass) Stats tracking
this bug's URL: http://intevation.de/rt/webrt?serial_num=3432
Subject: Stats tracking
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
GRASS Version: 6.0
Dave Sampson
Stats tracking of GRASS operations dunped to text log file.
eg what operation was used for how long. how many iterations?
present option for user to provide this data back to central server. process the data to see what areas of GRASS and what moduals are most often used.
This can help decide where development focuses should continue, or if something is under developed based on its use or lack of use.
GRASS Version: 6.0
Dave Sampson
This could be done by adding some code to lib/gis/parser.c
which simply writes all GRASS commands into a text file (probably
with time stamp). The file should be stored in the mapset
directory.
I would be interested to see some stats on my own commands...
