[GRASS5] [bug #3437] (grass) Error when importing e00 file
this bug's URL: http://intevation.de/rt/webrt?serial_num=3437
Subject: Error when importing e00 file
Platform: other
grass obtained from: Mirror of Trento site
grass binary for platform: Downloaded precompiled Binaries
GRASS Version: 6.0.0
I am Olympian, when I try to import e00 file into a vector map, the following appears....
v.in.e00 file=root/Desktop/c1000/e00/2se2d/aplicence.e00 type=-area
E00 ASCII found and concerted to Arc Coverage in current directory
Importing...
v.in.ogr: symbol lookup error: v.in.org: undefined symbol: OGRRegisterAll
Import area vectop map <DEFANGED_applicence>.
Done.
After importing the map, nothing can be displayed!!
Please help me solve the problem~~~
Thank you very much!!!
Platform: other
                                                              ^^^^ don't put '-' here
Importing...
This looks like a local error of OGR installation.
First check if ogr2ogr/ogrinfo work. v.in.e00 is a simple script...
