[GRASS5] [bug #3469] (grass) about i.class
this bug's URL: http://intevation.de/rt/webrt?serial_num=3469
Subject: about i.class
Platform: GNU/Linux/i386
grass obtained from: CVS
I am working with GRASS61, I try with i.class for supervised classification. After drawing the region on image I click to the Analyze region Menu, I get this error message WARNING:PREPARE_SIGNATURE: DATA ERROR (CLICK MOUSE TO CONTINUE). It seem that all the regions that I chose before now disappear. I try again with GRASS57, the result is also the same. Can you solve this problem for me? Thank you very much,
Best regards,
Tran Van Anh
Best regards,
Tran Van Anh
I traced this back to INAME_LEN being changed from 30 to 256 in
include/imagery.h.
This makes lib/vask/V_ques.c: V_ques() bomb out starting at line:
if ((length <= 0) || ((length + col) > 80)) ...
where the variable 'length' is passed in as INAME_LEN.
The program keeps running until it dies with a floating point exception.
Brad Douglas <rez@touchofmadness.com>
> Best regards,
> Tran Van Anh
include/imagery.h.
Brad,
the bug discovered by you is probably a new bug.
Miss Van Anh reports that GRASS57 also failed.
For testing, the LANDSAT-7 scene prepared for the Spearfish location
http://mpa.itc.it/grasstutor/data_menu2nd.phtml
-> p033r029_20000712_NAD27_small.tar.gz
may be used.
for i in p033*.tif ; do
    NAME=`echo $i | cut -d'_' -f4`
    r.in.gdal $i out=$NAME
done
i.group gr=lsat subgroup=lsat in=nn10,nn20,nn30,nn40,nn50,nn70
i.class
i.class
V_ask error: Length out of bounds in call to V_ques
Now I see the new bug, coming from
lib/imagery/
vask_group.c: V_ques (group, 's', line++, 10, INAME_LEN);
Attached patch cures *this* problem. Apply to CVS?
Then I made a quick test using i.class.
For me the reported error "prepare_signature: data error." doesn't happen.
(attachments)
vask_group.diff (1.14 KB)
include/imagery.h.
The attached patch changes V_ques() so that it truncates the length so
that col + length <= 80 rather than returning an error. It also
requires the starting column to be less than 80, rather than less than
or equal to 80.
The caller doesn't actually check the return value of V_ques(), and I
suspect that this is quite common. Maybe V_ques() should just use
G_fatal_error()?
Or maybe the imagery stuff should be weaned off of vask altogether.
AFAICS, the only code in 6.1 which still uses vask is:
  i.ortho.photo
  lib/imagery
  set_data
  r.le.setup
  v.transform
lib/edit also uses it, but lib/edit is only used by set_data.
(attachments)
V_ques.c.diff (897 Bytes)
> include/imagery.h.
or equal to 80.
G_fatal_error()?
I vote for applying Markus's quick-fix patch and filing a bug until a
more appropriate solution is developed (getting rid of vask?).
On Mon, Aug 08, 2005 at 03:29:56PM +0100, Glynn Clements wrote:
Content-Description: message body and .signature
> include/imagery.h.
or equal to 80.
G_fatal_error()?
  i.ortho.photo
  lib/imagery
  set_data
  r.le.setup
  v.transform
Applying Glynn's patch and modifying imagery/vask_group.c back
to INAME_LEN and layout cosmetics, we could have:
LOCATION: spearfish60 SUPERVISED CLASSIFIER MAPSET: user1
Please select the group/subgroup to be analyzed
           'list' will show available groups:
GROUP: ______________________________________________________________________
           'list' will show available subgroups:
SUBGROUP: ______________________________________________________________________
If it looks reasonable, I'll submit - or modify to your suggestions.
