[GRASS5] [bug #3515] (grass) r.surf.contour: max output=10*max input
this bug's URL: http://intevation.de/rt/webrt?serial_num=3515
Subject: r.surf.contour: max output=10*max input
Platform: GNU/Linux/i386
grass obtained from: CVS
GRASS Version: 61 cvs 09.08.05
# I did the following:
r.surf.contour -f input=melio_poz_clear_rast output=melio_poz_clear_rast_10_dem
# in a region of:
GRASS 6.1.cvs (caves_utm33):~ > g.region -p
projection: 1 (UTM)
zone: 33
datum: wgs84
ellipsoid: a=6378137 es=0.00669438
north: 5679480
south: 5679190
west: 601920
east: 602250
nsres: 10
ewres: 10
rows: 29
cols: 33
# The max output is 10 times more than max input!!!, see:
# the input
r.info -r melio_poz_clear_rast
min=9250000.000000
max=10025000.000000
# the output
r.info -r melio_poz_clear_rast_10_dem
min=9250000.000000
max=131410297.000000
What's interesting, this *error* high values seem to be *concentrated* in the lower-left corner of the output, *where no input data is present* see:
http://www.biol.uni.wroc.pl/sieczka/udostepnione/output_max_10times_too_high.png
The yellow background is the output DEM, the colour overlay is the input. Black arrow indicates the error (red perdendicular lines).
Maciek
P.S.
Could it be raleted to the "dozens of warnings" http://intevation.de/rt/webrt?serial_num=3514&display=History issue?
